Go to Post That sound you hear is of every programmer in the country cringing at the thought. - Billfred [more]
  #31   Spotlight this post!
Unread 02-01-2012, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Re: A Physics Quiz of a different type
Someone else offered an explanation as well:
As you gain energy, the mass of the object increases, because energy has weight. This includes kinetic energy. So as speed increases, so does mass, requiring more and more energy to maintain acceleration. At some point, it gets really massy, such that you can't push it hard enough to accelerate it.
I am told that this "weight gain with energy" has actually been measured, but I can't find that reference.
OK, does a photon have mass? If yes, then it cannot travel at the speed of light, but since it does, at rest it must be massless. (Yes, it has momentum, but that's a special case. In theory you can approach the speed of light using a flashlight as your propulsion unit. Might take a while though...)
Are there any nonzero-mass particles/objects that travel at c? Can there be?
  #32   Spotlight this post!
Unread 03-01-2012, 10:25
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Eh, why try to travel so fast when we could instead slow light to a crawl? The applications for that seem more pragmatic in our lifetimes than attempting to do anything at light speed.
For instance, could we trap light (and thus its energy) in order to accumulate enough for release when we want it? It'd bring a whole new meaning to 'solar energy'. There's been some work already in that direction and it seems at least a little less complicated.
2017 Scoring Model
CAD Library | GitHub
  #33   Spotlight this post!
Unread 05-01-2012, 12:53
Taylor's Avatar
Taylor Taylor is online now
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Related, and asked by a student to me a couple weeks ago:
When light is reflected, at the point of reflection, is the speed zero?
Hi!
  #34   Spotlight this post!
Unread 05-01-2012, 12:56
No. There is no "point" of reflection, because of the quantum mechanical wave/particle duality of the photon.
  #35   Spotlight this post!
Unread 05-01-2012, 14:08
Aren Siekmeier's Avatar
on walkabout
The fact that photons travel at the speed of light is exactly what originally motivated the fact that they are massless.
Using a flashlight for propulsion would definitely work (albeit very slowly) because of the momentum of the outgoing photons, but it is no different than any other Newton III interaction; you will still accelerate only asymptotically to the speed of light.
  #36   Spotlight this post!
Unread 09-01-2012, 09:44
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Okay, are you ready?
If you go at the speed of light, assuming you can in the first place, you will either dissolve at a sub-atomic level instantaneously, or merge into light.
Brings a new meaning to "don't go into the light...", doesn't it?
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
  #37   Spotlight this post!
Unread 09-01-2012, 10:09
Sitting in your chair looking at your computer monitor, you are traveling at the speed of light (with respect to the photons coming off your monitor).
Have you dissolved yet ?
