Go to Post In any case, a drawing is important. You should never machine anything without having a drawing of some type to work from. - Big Ideas [more]
Unread 04-01-2012, 21:19
Nikkocharger's Avatar
Nikkocharger Nikkocharger is offline
The R/C'er
AKA: Dontae
FRC #3398 (Crushing Crusaders)
Nikkocharger will become famous soon enoughNikkocharger will become famous soon enough
Rack and Pinion Style Robot.
Hello Everyone,
I am pretty new to all of this robotics stuff, I am more of a car person. So when my school's robotics team was showing me their previous robots and some other team's creations I noticed that all of them had a 6 or 4 wheel skid steer set-up. Now using my previous experiences I wondered why no other team uses rack and pinion steering like a car I mean its durable, also using four wheel steering like the Gmc Quadrasteer you can turn on a dime just like skid steering.
Thanks in advance to any responders.
Unread 04-01-2012, 21:21
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Rack and Pinion Style Robot.
It's also called Ackerman(n) steering and you should be able to find some threads using the search function found above. Ackerman limits your maneuverability and adds unnecessary complexity to a robot that would be more maneuverable with a much simpler tank drive.
I'm also going to beat SuperNerd in welcoming you aboard!
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 04-01-2012, 21:22
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
With a 6wd dropped center, you could literally spin centered above a dime. I've never seen a car come anywhere near a 0 turning radius.
Unread 04-01-2012, 21:25
Andrew Lawrence
Posts: n/a
Teams have done it, but it's not as favorable. You don't get as much pushing power with 2 motors powering the bot, and you can't maneuver as fluidly as other drives. We used this in 2008, if memory serves correct, and it didn't work out so well.
Since you're a car guy, I'll put it like this. In a pushing match between 2 cars. both with the same weight, traction, and motors, who would win: A standard car, or a car with power to every wheel? Or a car with more wheels and power to them, for that matter.
Also, which is more maneuverable: A standard car, or a wheelchair?
Hope this helps!
Unread 04-01-2012, 21:26
Andrew Lawrence
Posts: n/a
WELCOME!
Ninja, this is what a welcome is like.
Unread 04-01-2012, 21:30
Ninja_Bait's Avatar
AKA: Jake Potter
phooey on you.
WELCOME!
how's that?
Unread 04-01-2012, 21:33
Andrew Lawrence
Posts: n/a
Originally Posted by Ninja_Bait View Post
phooey on you.
WELCOME!
how's that?
Eh, could be better. The colors make it distracting to read and take away from the reader's interest.
Unread 04-01-2012, 21:38
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
There are some glimpses of a nice little Ackerman steering lapbot (2261) in this video from Colorado 2008.
http://www.youtube.com/watch?v=52PxEzpm9Us
Unread 04-01-2012, 22:00
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
You could power all of the wheels with Ackerman, which would minimize or eliminate the loss of traction by less normal force on drive wheels.
More wheels does not mean significantly more traction, though some people have found small benefits to having more tread on the ground, this effect is secondary to the type of tread and the weight of the robot.
Depends what you mean by maneuverability. It improves your ability to turn while driving at high speeds and move in arcs, but it makes turning on a dime difficult or impossible.
Other than 2008 (which had several Ackerman robots), most games have not required the kind of smooth arcing motion Ackerman is capable of. Most motions tends to be like go-stop-turn-go-stop-turn-go, which is what skidsteer is good at.
This is the main reason why most teams stick with skid steer. The kitbot is skidsteer, and can be built in one day. Even a custom chassis skid steer does not take very long to fabricate, compared to an Ackerman drive. Additionally, it usually uses steering motors that could be used elsewhere (and if you want to keep those motors down to just one or two, instead of four, you must design a linkage to keep them at the proper angles). Skid-steer's simplicity makes it much easier to have a moving chassis early in the season, and to have more time and resources to use on a manipulator.
Unread 05-01-2012, 02:19
Y'all forgot the biggest reason not to go with Ackerman drive. It's called Swerve Drive. For making two more wheels able to turn (and the two that turn in Ackerman turn more fully), you get to move in any horizontal direction without turning at all!
Besides the limited turning ability--an Ackerman has to do a Y-turn to accomplish what a skid can do with a simple spin--it's a somewhat complex drive. While swerve (or mecanum or omni) is also complex, it's somewhat of a simpler type of complex.
Unread 05-01-2012, 13:37
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Ackerman was a good drive choice for that game. The aft end of the robot would follow the forward steering wheels. There were penalty points for going the wrong way around the track. So if you were going to build a speeder to rack up running / lap points it would have been the way to go. A number of teams had auto mode that could score 3-4 laps in the first 20 seconds.
In game play, this is one of my favorite games. The combo of kickers, placers and speeders made for some pretty amazing game play moves.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 05-01-2012, 13:44
The R/C'er
AKA: Dontae
Ok I get it now teams use tank (skid) steering because it is easy to build and very simple to work on plus you can power more wheels.
Thank-you all very much
Suddenly, a wild prototype appears!
Unread 05-01-2012, 14:02
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Well to be fair, I think the consensus in this thread (and in FRC in general) is that the main benefit of Tank/Skid/Differential vs. Ackermann is that it is much better for maneuverability over short distances and/or slow speeds. The common story I give to my students is this:
How many turns/maneuvers does it take to move a car into a parallel parking space? How long does this take?
If you have a robot that needs to pick up a ball that is 3 feet to your right, and you have Ackermann steering, how long would it take to get there? If you had tank/skid/differential steering, how long then?
Ackermann is much better when you have high speeds and/or turns that do not require any form of strafing translation, i.e. like a race track. The OverDrive Game was designed to mimick a race track, hence several teams going after the Ackermann design and some were very successful. However (in my personal opinion) in most games in the past most teams with Ackerman steering would be at a huge disadvantage compared to a simple skid steering robot, with just looking at maneuverability by itself and not considering complexity/cost/use of motors/resources, etc.
Unread 05-01-2012, 14:16
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Just a little side information, Ackermann steering refers to a specific type of car steering geometry. With Ackermann steering, the wheels will actually be at different angles during steering travel to more accurately approximate the path in which they are traveling. Cars have Ackermann steering for a variety of reasons: decreased scrub, better front end traction, etc.
Here's a picture to explain further:
Not all 'Car Style steering' in FRC is necessarily Ackermann Steering, some teams in 2008 used parallel steering to some success, among other methods.
-Dustin Benedict
Unread 05-01-2012, 15:34
The R/C'er
AKA: Dontae
This is just a picture I found on team 2261's website showing the ackermann set up.
