Go to Post I think FIRST is a big trap. They lure you in with these cool competitions and shiny robots and along the way they trick you into learning something :) - =Martin=Taylor= [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 04-01-2012, 21:04
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
CADing Gears
How does one cad spur gears in solidworks? And how would they be manufactured?
Unread 04-01-2012, 21:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: CADing Gears
Don't. Download them from McMaster, SDP, etc.
They are manufactured in a number of ways. Most common would be hobbing and shaping.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-01-2012, 21:13
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: CADing Gears
Are you looking to model the gear exactly, or roughly for basic design work? (If exactly, see below; if roughly, use a cylinder the size of the pitch diameter.)
And will you be manufacturing gears yourself, or are you just wondering how gears are made industrially? (Either way, some ideas and references are presented below. The usual mass-production way is hobbing, but many other methods exist.)
Lots of existing threads on these topics exist (often with links to external tutorials). Some examples:
Unread 05-01-2012, 16:24
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: CADing Gears
If you aren't planning on rendering the gear for any reason, just use a cylinder (i.e a 20 tooth 20 dp gear .4 inches thick becomes a 1 inch diameter by .4 inch high cylinder).
If you are planning on rendering then download the models from here
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 05-01-2012, 16:41
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: CADing Gears
It's usually much easier to buy gears than it is to manufacture your own. Some sites like McMaster Carr have CAD models of the parts they sell, so there is no need to create your own model.
If you need to create a gear in Solidworks that you can't find a model for, the Toolbox works very well. In an assembly you can insert a part that has the desired number of teeth and diametrical pitch, then edit it if necessary.
Unread 05-01-2012, 17:11
Best Available Data
FRC #1778 (Chill Out!)
Re: CADing Gears
If you are interested in the math behind an involute gear and how to sketch one, this online tutorial is a good one to follow.
If you want to draw gears to design and build crazy mechanisms and cut them yourself (you'll want a CNC machine), the guy responsible for Mach3 has been developing Gearotic Motion, which is a pretty incredible tool. It is free to download and play with, and only $75 if you want to be able to export the gears.
Unread 11-01-2012, 11:05
kinghashbrown kinghashbrown is offline
Lead Designer and Team tri-captain
AKA: Joey Fisher
FRC #0176 (Aces High)
Team Role: CAD
kinghashbrown is an unknown quantity at this point
Re: CADing Gears
I use toolbox for gears. It's also good for sprockets and bolts.
Unread 22-01-2012, 21:08
junefish's Avatar
junefish junefish is offline
CAD . . . so easy yet so hard . . .
Team Role: Electrical
junefish is an unknown quantity at this point
Re: CADing Gears
I definitely agree that you should either download the CAD file from McMaster-Carr (et cetera) or utilise the Toolbox. If not, a "simple" CAD will suffice--i.e., a cylinder. If you actually want to CAD the gear, however, I believe that you attach half an ellipse to a circle & use a Rotational Sketch Pattern to surround the rest of the circle.
~junefish
Thirty-nine decimal places of pi suffice for computing the circumference of a circle girding the known universe with an error no greater than the radius of a hydrogen atom.
Unread 22-01-2012, 21:19
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: CADing Gears
FIRST Team 1296 borrowed a technique from the robo-wranglers. We make exotic-shaped aluminum gears from sheet metal and rivet them together to get the desired width. They would not last long enough in an industrial setting but on a FIRST robot, they are good enough. It works for us since we have an awesome sheet metal company as a sponsor.
HTH
Unread 14-02-2012, 17:50
Exla357's Avatar
Exla357 Exla357 is offline
Certified Joystick Pusher
FRC #0159 (Alpine Robotics)
Exla357 will become famous soon enoughExla357 will become famous soon enough
Re: CADing Gears
There is a simple way to do it on Solidworks 2009, but it takes a lot of time because gear mates have to be made for each "tooth"
Make a cylinder, on say the Top Plane. Now, create a new sketch on the same plane as a point for the extruded cut that will be the airspace between the gears (if that makes any sense). Now, make the extruded cut. In features, select the pattern tab and choose "Circular Pattern." Select the extruded cut, check "Equal Spacing." For Parameters, select one of the edges of the circle. Now, increase the number of features until you get what you like, than accept.
Hope that made sense.
-Alex
