Go to Post Advances in STEM are meant to benefit everyone, so even the most basic-level of understanding deserves to be validated and encouraged. - moamomen [more]
Unread 05-01-2012, 17:33
Re: Labview solenoids...
Measure the voltage at the solenoids and compare it what the solenoid's coil is expecting. It is possible that you either didn't power the module correctly, or are driving a 24V coil with 12V.
Unread 05-01-2012, 19:01
The power/ground to the solenoid could also be reversed and get a similar reaction. A simple test for that possibility is to reverse the connector at the solenoid module. Having it backwards doesn't harm the solenoid, and if it has an indicator light, then the light will work, but the solenoid won't move.
Another potential cause depends on the type of solenoid you are using.
Older plastic Festos had two conflicting wiring schemes.
What model is it?
Unread 05-01-2012, 20:01
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Actually it works now. Turns out it was the wrong power cord. Thanks for the help everyone! Really appreciate it!
