Go to Post I understand that Dean Kaymen has now invented a super "sniffer" that can scout-out anyone within hearing distance that is remotely-involved with FIRST. - dhitchco [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-12-2011, 21:57
Glitch_94's Avatar
Glitch_94 Glitch_94 is offline
AKA: Harrison Shipp
FRC #3374 (RoboBroncs)
Glitch_94 is an unknown quantity at this point
Questions For T-Slot
Hello again, So my team Is still looking at ordering a lot of T-Slot Stuff, I was wondering if anyone could help out and give us a good list to start off with. We will be using it to prototype our robot before the final build and we wanted somebody's list of parts that have worked out great for them in the past. Thank you guys in advance!!
Unread 20-12-2011, 17:48
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
Re: Questions For T-Slot
A lot of teams use 80/20, but we use Bosch Rexroth aluminum structural framing. To start off with, you will need the material (I recommend 30mm), brackets, and the bolts with the special t-shaped nuts. Other useful components include hinges, nylon sliders, and plastic end caps.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 20-12-2011, 23:52
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
The self tapping screws from Bosch are also very helpful.
I would also suggest getting 3000mm of 20mm profile and 3000mm of 30mm as the different sizes can become quite useful. If you do buy the 20mm then you also will need to buy some connectors.
Unread 26-12-2011, 20:42
chuckmerja chuckmerja is offline
FRC #1696 (RoboRevolution)
chuckmerja is an unknown quantity at this point
So 1" would be OK if buying SAE stuff? vs the 1.5"? I didn't price the Bosch stuff, but it appears T-slot (http://www.tslots.com/) is cheaper than 80/20 (http://www.tslotparts.com/) (http://www.8020.net/T-Slot-1.asp) after discounts for students/roboteers. Are they interchangeable??
2005 - Sacto quarterfinalist
2006 - Sil Valley quarterfinalist
2007 - AZ semifinalist, 2 judges awards, Woodie Flowers Award
2008 - smallest team from smallest school in FIRST - 3 person team!! - Seattle semifinalist
2009 - let's just say this bot would not have qualified for a trip to Mars
2010 - redoubled quality effort - won quality award and WINNER Utah Regional (first MT team to win an FRC regional) also won state FTC tourney (team 724)
2011 - Finalist UTAH regional
Unread 26-12-2011, 20:52
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
80/20 will give discounts to FIRST teams. I have also heard of Fastenal giving discounts on 80/20.
YOU can also check the 80/20 Ebay page for some great deals.
Unread 26-12-2011, 22:27
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
1073 regularly uses builds our chassis from 8020 - the 1 inch "1010" series.
The following fasteners are the ones we use most. The price is from an order a couple years ago, but it will give you an idea of what to expect.
Part Number Price
Butterfly 3381 $1.50
Single Plate 3382 $0.21
Double Plate 3280 $0.69
Drop in 3376 $1.70
The butterfly's are used for right angle mounting.
The single and double plates are for general purpose mounting of other items to the 8020.
The drop-ins allow you to add a fastener into the t-slot without taking an end off to slide it in.
A handful of their T plates and other corner brace plates are useful.
A handful of 1" triangles for the inside corners are also useful
(Sorry, don't have the part numbers handy.)
You will need a variety of 1/4-20 machine screws. I recommend hex drives, and some T-handled hex wrenches.
Hope this helps.
Unread 26-12-2011, 23:06
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Part Number Price
Drop in 3376 $1.70
What supplier was this order for? Also, is what you term a "butterfly" just a corner or L bracket?
Most 80/20 hardware, as far as I'm aware, has 1/4-20 threading; make sure to have a variety of lengths below 1" for mounting. Depending on the application, you'll want either a corner or L bracket (both of which are compatible with extrusion).
Having some 1/4-20 taps on hand may prove useful as well; we occasionally find threading the center tube to be useful when mounting pieces.
You may want to buy some other materials, such as wood or lexan - cardboard even - for prototyping; there's only so much you can do with 80/20, and it's sort of overkill for a proof of concept imo.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 27-12-2011, 03:24
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Butterfly he means end fastener those are 8020 parts
Bar 1 has the butterfly screwed into the hole running down the center by tapping the hole
Bar 1 is attached to bar 2 by sliding the butterfly in like a tnut and tightening it down through a hole in the bar called an access hole
See the second page of here http://download.8020.net/2011_Produc...Catalog_17.pdf
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 05-01-2012, 17:56
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Free t-slot design software here: http://www.framexpert.com/
