Go to Post Sleep is for the weak - TEntwistle [more]
Unread 05-01-2012, 17:18
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
Re: Rack and Pinion Style Robot.
my team's pretty still pretty young but we've been trying to test different drive trains. we've used tank and mecanum so far. we always do a lot of research and last year we were thinking of using swirve which is based of cars. we were worried about a few things. that swirve is still relativity new and that we did not think that we had enough time to work on it. there are some teams that use swirve but it takes dedication for months to make it work correctly. Getting it to work the way you want it to is not easy. So if your team has the time and resources, I would recommend that they start researching and prototyping this idea during the off-season. my team plans to do the same. this reduces the risks of having your robot not fully function during competitions.
good luck!
This is not only for your idea but for everything you do in robotics! wouldn't you rather know that your team has build something that actually works, and works well? this is why veteran teams often do well: they have experience.
College Student | "It won't fail because of me."
Unread 05-01-2012, 18:39
Originally Posted by thefro526 View Post
Ackermann steering refers to a specific type of car steering geometry. With Ackermann steering, the wheels will actually be at different angles during steering travel to more accurately approximate the path in which they are traveling.
If you have independently steerable front wheels, you can do Ackermann steering in software.
Unread 05-01-2012, 18:58
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Another very important reason skid steer "trumps" any car-like driving method is that skid steer keeps the middle of the machine open for game functions. For example, in 2010 it would have been difficult to make a kicker work around this or in 2009 or 2006 it would have been more difficult to pick up balls from the ground. The front-middle of the robot is prime robot real estate.
Plus that whole thing with it being more complex and less manuverable.
Regards,Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 06-01-2012, 17:56
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
As pointed out once before in this thread, there is no reason you cannot power all the wheels in an Ackermann steering system.
The more pertinent concerns deal with desired performance, weight and space allocation, points/modes of failure, and familiarity.
Unread 07-01-2012, 11:06
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
it would be probably at least twice as heavy, because you need a rack and pivoting wheel mounts, like the ball joints in cars.
look at skidsteer equipment, and the kind of small spaces they operate in, and compare that to driving a car.
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
