Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 05-01-2012, 19:22
Andrew Lawrence
Posts: n/a
15 tooth + double sprockets
Does anyone know where I can find #35 double sprockets greater than 15 tooth? I've searched for a while on Google, but haven't been able to find them. Andymark only has 15 tooth ones max.
Thanks!
Unread 05-01-2012, 19:46
Mrpalmere Mrpalmere is offline
Chief 1/2 bot builder
#1089 (Team Mercury)
Mrpalmere will become famous soon enoughMrpalmere will become famous soon enough
Re: 15 tooth + double sprockets
You can try mcmaster.com, they show a double strand sprocket up to 20 tooth. You may hex broach the sprockets and put them on a live axel. Use hex shaft and turn down the ends to fit your bearing. I'm sorry if you don't have the facility to do this. send me a message and I'll help you with it as I have the tools ready for your use. mrpalmere@verizon.net
Unread 05-01-2012, 19:49
Andrew Lawrence
Posts: n/a
Thanks all! I looked on McMaster and the only double sprockets they had weren't like the ones in the kit of parts, or at least didn't look like them. The one in the kit of parts is essentially the one we need, however we'd prefer a larger sprocket than what Andymark offers. Plus, a key broach is sorta what we're going for.
Unread 05-01-2012, 19:51
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Double strand is not the same as double sprocket. Double strand is meant for 35-2 chain, unlike the AndyMark-type double sprocket, which is meant for two separate loops of 35-1 chain. I don't think you can use the former as a substitute for the latter, because the separation between sprockets is too tight.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 05-01-2012, 19:54
Andrew Lawrence
Posts: n/a
Yeah. Sorry for not clarifying. I need to know where I can get a +15 tooth double sprocket, not a double strand. My bad for not being clear.
Unread 05-01-2012, 19:58
Ninja_Bait's Avatar
AKA: Jake Potter
Originally Posted by SuperNerd256 View Post
Yeah. Sorry for not clarifying. I need to know where I can get a +22 tooth double sprocket, not a double strand. My bad for not being clear.
It's less a clarity issue than an availability issue. Most (probably almost all) "double sprockets" are made for double strand chain, so even I slipped up on that point from my initial Google search. Alas.
Back to the search engine!
Alternatively, make your own by bolting two sprockets together (actually, that sounds kind of fishy engineering to me...) or machine it.
Unread 05-01-2012, 20:02
Andrew Lawrence
Posts: n/a
We're not very good in machining sprockets, and the build season isn't a time to try it out for the first time.
Unread 05-01-2012, 20:06
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
I do think double sprockets will be hard to find, especially if you want them in aluminum like the andymark ones.
Although a machined double sprocket would probably be inherently stronger, I don't see why bolting sprockets together would be "fishy engineering." If the bolts are properly sized, there's no reason for them to fail. Bolts are used to transfer rotation between two parts on dead axles all the time, so why not between two sprockets?
Alternatively, you could simply use two broached sprockets, mounted back-to-back on the same shaft.
Unread 05-01-2012, 20:09
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
It's a little more expensive, but you can use 2 AM sprockets & a hub, bolted together. For example, 22 tooth use 2 AM S35-22 & 1 AM0096
Edit: posts above while I was writing. I wouldn't call it "fishy engineering", multiple sprockets are bolted together often, for example, many 6 or 8 wd drivetrains have multiple sprockets bolted to wheels to power adjacent axles.
Unread 05-01-2012, 20:22
Ninja_Bait's Avatar
AKA: Jake Potter
I just try to be wary of slapped-together, poorly thought-through, solutions, and that was very much a spur of the moment idea.
Unread 05-01-2012, 21:42
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: 15 tooth + double sprockets
http://www.3dcontentcentral.net/3DCo...aspx?id=290003
you could assmble 2 of these together on the same shaft maybe?
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 05-01-2012, 22:11
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You can't; it's not really a thing that's used often in industry in my experience.
--Madison--
...down at the Ozdust!
Unread 05-01-2012, 22:35
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Are you looking for something like this?
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 05-01-2012, 22:36
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Bolting two sprockets together is popular and I have used it without any problems. Any pair of AM sprockets, properly sized bolts, and spacers (possibly the AM Delrin) should be fine. If you want something proven try these:
http://www.vexrobotics.com/products/...hdwr-dual.html
Unread 05-01-2012, 22:37
Andrew Lawrence
Posts: n/a
I think you may have solved all of my problems! Thanks!
