Go to Post According to a recent study, 63% of teams admit they are behind. The other 37% are lying. - nitneylion452 [more]
Unread 05-01-2012, 22:54
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: 15 tooth + double sprockets
Originally Posted by SuperNerd256 View Post
I think you may have solved all of my problems! Thanks!
I don't want to burst your bubble, but all that does is bolt two sprockets together
--Madison--
...down at the Ozdust!
Unread 05-01-2012, 22:55
Andrew Lawrence
Posts: n/a
aww.
Unread 05-01-2012, 23:05
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
I don't know if they offer 15T with that hub. That system does allow for a double sprocket (2x single strand). I know for a fact that Linn-Gear offers the ability to weld an A (hub-less) sprocket and a B (hubbed) sprocket together as well as what ever bore and broach needed. They are open 24/7 and have great turn around times since they not only support manufacturers but our local logging industry, or what's left of it.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 06-01-2012, 00:18
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: 15 tooth + double sprockets
http://challengept.com/flipcatalogue...pageNumber=126
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 06-01-2012, 00:22
Andrew Lawrence
Posts: n/a
Originally Posted by Scott L. View Post
I can't tell by the picture if these will work or not. They look like it, however it needs to resemble the one from Andymark and be a key bore. I can't find anything on the page saying so.
If it works, then my problems are solved!
Unread 06-01-2012, 00:27
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
http://www.vexrobotics.com/products/...hdwr-dual.html !!!!!!!!!!!!!!!!!!!!!!!!!!
EDIT: Fixed
Unread 06-01-2012, 00:28
Andrew Lawrence
Posts: n/a
Originally Posted by lemiant View Post
Error 404: Page not found. :|
Unread 06-01-2012, 00:37
Andrew Lawrence
Posts: n/a
EDIT: Fixed
Found what you're looking for: http://www.vexrobotics.com/products/...hdwr-dual.html
Looks good, but how far apart are the sprockets spaced? They need to be the same space away from each other as the ones from AndyMark are.
Plus, it's for a CIMple box output shaft, so they'll need to fit there on the key bore and everything.
EDIT: I did the math (Haven't saved the world yet, build hasn't started), and found out that if I use smaller sprockets on the wheels, I can get the preferred speed. So since I also can't find any wheel-mountable sprockets smaller than 22 teeth, does anyone here know of any smaller sprockets that are also wheel-mountable? This should be easier to find then the double sprockets.
Unread 06-01-2012, 01:31
ttldomination's Avatar
Sunny
Well, saying you want a wheel mountable sprockets is like telling us you want an umbrella with a stick.
As you might have guessed, there are many variables about aforementioned wheel. But, using my excellent literary analysis skills, I'm going to assume you're going to be using AndyMark wheels.
Using 'small' sprockets on the AndyMark wheels can prove a bit challenging. First off, 'small' isn't very specific, but there are a couple of...regions of small.
So, from my knowledge of the Andy Mark Plaction Wheels, you can get away with a #35 chain sprocket of at least a 24 teeth without having to use the 1/4" spacers. If for some reason you need exactly 22 teeth, you're going to need to use the 1/4" space so the chain doesn't hit the wheel hub.
Any smaller than 22 teeth and you're looking at a live axle system. For this, I would recommend using the AndyMark Performance Wheels. From here, you can buy the sprockets which are hubbed with keys or hex from nearly anywhere and just slide them onto the axle.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 06-01-2012, 01:37
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
I think he means wheel mounted as opposed to put on a live axle.
Unread 06-01-2012, 03:23
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
As to your original question, the term you want is a "double single sprocket" or "double simplex sprocket". Like these:Unfortunately, most often they seem to be typically available for ANSI #40 roller chain and larger, or British 06 chain (which I doubt would match). (Some are in China, so there's the distribution problem as well.)
There's always custom fabrication—these guys say they can make it—better still, find a sponsor to make it.
(In case you're wondering, these double single sprockets are used in some conveyor systems.)
Unread 06-01-2012, 06:41
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
The wheels (the mounting part, not the tread surface) can also be turned down to a diameter that will allow the chain walls to fit. But you're still limited to 22 teeth because of the size of the bolt circle AndyMark uses. To wheel-mount a smaller sprocket you'd have to make a new bolt circle on the wheel and sprocket somehow.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 06-01-2012, 08:54
Andrew Lawrence
Posts: n/a
Ok, here's the clarification:
For my drive, there is a 15-tooth double sprocket on the CIMple box output shaft. That will be connect by #35 chain to the wheels via a 22 tooth sprocket. However, to achieve the speed desired, I will either need to increase the size of the double sprocket, or decrease the size of the sprocket attached to the wheel.
Again, thanks to all of those who have answered so far, I really appreciate it, since I'm mechanically dumb (so far).
Unread 06-01-2012, 09:37
Ninja_Bait's Avatar
AKA: Jake Potter
Can you just reduce the max speed in code? Or does that cause too much of a loss in torque?
Unread 06-01-2012, 09:41
Andrew Lawrence
Posts: n/a
We can, but we're trying to increase the max speed. It's currently at 10.97 fps, however we want to see if we can go higher than that.
ALSO, I have noticed some people saying that by using the 22 tooth sprocket from Andymark, the chain won't fit. Is that because of the wheel, or something else? I'll be using 4" plaction wheels.
