Go to Post Build season can't come soon enough. - Ryan Dognaux [more]
Unread 06-01-2012, 08:00
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Turning Off Command Alias Input
I am currently in Manchester for the Kick Off and will send a reply later today / tomorrow. This may be an OS issue that I have seen with how Inventor reads the keyboard input. Speak with you soon.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 06-01-2012, 10:13
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
The same thing was happening to me for a while with the 2011 build of Inventor. What it seems to mean is that there are multiple inputs with the same letter as you've entered. As in the example in the image, constraining would require you to press "C">"Enter". To change the commands or turn off alias input, go into your Application Options.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
