#16
Re: Running the Kinect on the Robot.
I have a feeling that if you keep trying to fit more and more information in through the TCP/IP port, you will start having lag. If you have a second USB port, I would use a usb to serial converter to pass filtered data directly to the cRIO using a high baud rate. This would be easier to set up then a TCP/IP port, imho.
