Go to Post ...if you don't ask, you won't get. - Billfred [more]
Unread 06-01-2012, 10:39
Betty Boop Betty Boop is offline
Betty Boop is an unknown quantity at this point
RF Synchronization Suite
Hello! I’m currently trying the sample codes included in the RF Synchronization Suite which I downloaded from National Instruments website. However, I’m having a hard time understanding the effect of the “phase offset” on the IQ data which I generate (or acquire).
For the generation part, I’m testing the sample code named “PXIe-5673 Phase Coherent Arb Waveform Generation with NI-TClk Example”. If for example, I entered 0° as my phase offset for channel 1 and then entered 10° as my phase offset for channel 2, does that mean that my data for channel 1 is AMPLITUDE1∠0° and my data for channel 2 is AMPLITUDE2∠10° in polar form? If so, do I enter these values before running the code, or while running the code (and after which I click the “Update Phase Offsets” button)?
Thank you very much for your time! God Bless!
Unread 06-01-2012, 12:50
Re: RF Synchronization Suite
Hi Betty
The folk from National Instruments that frequent this forum specifically support high school robotics competitions. You are likely to find a better answer at the official NI support forums.
I was about to suggest http://forums.ni.com/t5/Signal-Generators/bd-p/310 , but it looks like you've already posted there.
Unread 07-01-2012, 10:23
Thank you, Sir!
