Go to Post We do not pursue awards, we pursue greatness and the awards follow. - Sunshine [more]
Unread 06-01-2012, 04:20
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Custom RobotDrive
Hi CD, I was wondering how to make a new class that implements the obejcts and methods from the RobotDrive. Right now all the code, which runs works fine, is all in one file. Which is not very neat so I am trying to create seperate classes for everything such as the arm ,etc. Since we used mecanum we had to invert the motors and set the pwm channels and everything which took up a lot of space, so, I want to make something like this: (just as an example)
DriveTrainMecanum DriveSystem = new DriveTrainMecanum(1,2,3,4);
In which DriveTrainMecanum implements all the methods and objects from RobotDrive but it also does the inverting of the motors and everything else. This is what i have so far but its saying "no suitable constructor" :S How do i fix this:
This is what i have written so far:
* To change this template, choose Tools | Templates
* and open the template in the editor.
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.SimpleRobot;
public class DriveTrain extends RobotDrive {
//This is going to be set by the user but iam just making it for now
Jaguar frontLeft = new Jaguar(1);
Jaguar frontRight = new Jaguar(2);
Jaguar rearLeft = new Jaguar(3);
Jaguar rearRight = new Jaguar(4);
public DriveTrainMecanum(int cone, int ctwo, int cthree, int cfour){
"A team back in training !"
Unread 06-01-2012, 11:43
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Custom RobotDrive
The easiest way to to this would be to remove the need for RobotDrive, and just copy the methods you need from that class to your custom class.
Team 4488 - Mentor 2013-2016
Unread 06-01-2012, 11:51
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
When subclassing you need to call a super constructor with the proper arguments. This has a few impacts. First of all, in your constructor, you need to call super(cone, ctwo, cthree, cfour). You should also not need your own instance variables to keep track of those jaguars, since RobotDrive already does.
If my train of thought was a little confusing let me know. Here is how I would modify the code.
super(cone, ctwo, cthree, cfour);
Unread 06-01-2012, 13:01
FRC #1514 (Vikings)
Originally Posted by linuxboy View Post
When subclassing you need to call a super constructor with the proper arguments....you need to call super(cone, ctwo, cthree, cfour).
What do you mean by "super constructor"?
Unread 06-01-2012, 14:21
perhaps a superclass constructor?
http://docs.oracle.com/javase/tutori...ndI/super.html
Unread 06-01-2012, 14:49
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Personally, I always just deal with the PWM class. I don't even bother with anything higher level than that. It just simplifies things by writing everything from scratch.
Unread 08-01-2012, 10:58
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
If that were simpler, there would not be any other classes on top of it. It's bad form to make your project more complicated for other team members and call it "simpler". If you want to increase the amount you code you write, simply admit your desire to your team and others who may be reading this. Please don't mislead others with claims like this.
Using the PWM class is the least simple way to control your robot drive base.
Joe
Unread 10-01-2012, 13:41
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Joe
I think what he meant was that when you write it all yourself you assure yourself it works exactly as you need it to. You have the greatest understanding of your code.
Unread 10-01-2012, 13:44
But what about the rest of the programming team?
Unread 10-01-2012, 18:29
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Comments, comments, comments. Just like how the rest of the world does it.
