Go to Post And just remember, it's an engineer's world. Without us, everyone is powerless, literally. - JoeXIII'007 [more]
Unread 06-01-2012, 16:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Autodesk Cloud
I'm trying to setup the Autodesk Cloud, as in the 1GB free version. Yet as I upload a few test files, I've noticed some very frustrating inconsistencies. Every time I upload an assembly and re-download it (testing collaboration out), the assembly file loses all links to the parts it contains. Has anyone else tried this, or can anyone recommend a revision control system for CAD?
If not, I suppose we can use Dropbox to share files.
GitHub
Unread 06-01-2012, 18:09
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Autodesk Cloud
Do you have a Project file set up that you are also uploading/downloading? That should keep the references.
Unread 06-01-2012, 18:30
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: Autodesk Cloud
You may need to upload the part files too?
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 06-01-2012, 18:45
JesseK's Avatar
FRC #1885 (ILITE)
Re: Autodesk Cloud
I don't have a project file, but I am uploading all required files. For example, I have a FieldAssembly assembly file that only has a "PlainFloor" component, and I upload both together. Upon re-download of both files, the FieldAssembly file brings up a dialog requiring me to re-link the PlainFloor component.
In re-watching the videos, it looks like most of what Autodesk demos for the Cloud are dwf files, which should be fine for viewing. I think what I'll do instead is use Google Code as a SVN repository, have the students use that for collaboration (with some rules), then publish .dwf's to Autodesk Cloud. That way the main build mentors (good with their hands, but not with CAD) can view the models and get dimensions when they need them.
I'll investigate the project file as well. Thanks for the responses!
GitHub
Unread 06-01-2012, 21:23
ElvisMom's Avatar
ElvisMom ElvisMom is offline
League of Mothers
FRC #1625 (Winnovation)
Team Role: Parent
ElvisMom has a spectacular aura aboutElvisMom has a spectacular aura about
I've exploring cloud solutions for our team too. I'll do some research on Google Code, but what do you mean by "with some rules"? Sure hard to sort out the browser plugs, etc.
Not too technical please. Thanks in advance.
League of Mothers Founding Member
"Four More Years"
Unread 06-01-2012, 21:52
JesseK's Avatar
FRC #1885 (ILITE)
Re: Autodesk Cloud
By "rules" I mean some ground rules between the students and I for who works on what, what to do about 'merges' (2 people updating the same file), don't do 'forks', and finally, naming conventions ([SubSystem]_[SubAssembly]_[PartName]). This way we can hopefully avoid problems along the way, like one of us overwriting the file that someone else just updated.
GitHub
Unread 06-01-2012, 23:28
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Autodesk Cloud
I believe you need to do what is called, "Pack and Go." To my understanding, it takes all related files to an assembly and the assembly itself and places it into one file that you can open up on any computer with compatible software without having issues with file linking.
Our team had quite the experience with this issue uploading our Inventor submission last year. We tested our submission and found that every file link of the over 5000 parts on our robot CAD was not working. We read up about a solution and pack and go came up. It was actually very useful!
Here is an explanation and quick tutorial on how it works.
Disclaimer: This might or might not be what you are looking for.
Unread 07-01-2012, 10:07
JesseK's Avatar
FRC #1885 (ILITE)
Re: Autodesk Cloud
Thanks! That looks similar to what we're looking for. I'll test it out today.
GitHub
Unread 08-01-2012, 13:14
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Autodesk Cloud
JesseK,
Keep me posted on how your testing goes. I have a meeting tomorrow with some other Autodesk folks and I can post any issues you might be having with the Cloud.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
