Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 18-12-2002, 22:32
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Else Statements!!!
Who else is annoyed about working with a language that doesn't have an else statement? I know that I, for one, can not stand having to write if statements that jump over other if statements that jump over gotos... Your thoughts?
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 18-12-2002, 22:35
Happy Birthday! rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Equivalent of else:
if <<something>> then trueLabel
<<stuff for else>>
goto endIfBlock
trueLabel:
<<trueStuff>>
endIfBlock:
It's really not that bad once you get used to it.
Unread 18-12-2002, 22:36
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
I'm learning it now, so yeah, it sucks. That's what AppleScript is for.
Unread 18-12-2002, 22:44
I agree that it isn't that bad after a while but still, it is quite annoying. Too many goto's. I would much rather work in just about any other language where I could use else statements, not to mention code blocks (C++, etc.). On the other hand, being so simple makes PBasic extrememly easy to pick up (took me about 2 days to get it down really well...).
Unread 19-12-2002, 10:34
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Hehe... you think this is bad? Try working on Assembly.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 19-12-2002, 13:31
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Some of us like assembly. Then again, I suppose x86 assembly is pretty bad (4 registers and a horribly complex addressing mode) as is ARM (where you have to manually stall the pipeline as it doesn't do branch prediction).
Matt
Unread 19-12-2002, 15:48
I guess that's true...I once took an attempt at assembly and gave up after only a few minutes. Maybe it just wasn't meant to be...
Unread 21-12-2002, 16:59
Mongoose's Avatar
Mongoose Mongoose is offline
#0948 (Newport Robotics Group (NRG 948))
Mongoose is an unknown quantity at this point
Send a message via AIM to Mongoose
I find it annoying that you skip over the next block of code if a condition is true. It's just not logical. You get used to it. If you really insist, there is a way for a plain old if-statement, though:
if(condition) then doStuff:
goto skipStuff
doStuff:
' Your code here
skipStuff:
Since it's winter break, I'm learning assembly right now for my TI83+ (z80 processor). It's not all that bad.
Unread 21-12-2002, 23:13
How are you learning it? I'm guessing online tutorials (that's pretty much how I learned all the programming I know...). I think I'll probably take another crack at it during vacation and see what happens...wish me luck...
Unread 22-12-2002, 01:27
The basis for this jump is the machine that was in the first BASIC Stamp - the PIC from Microchip. Its only decision is a flag-test followed by a skip over the next instruction to the instruction after that. It has one register you can load, and it is busy ! The on-board RAM is set up in 'files' : 8 bit locations you assembler allows you to name, and they do get cramped.
[compare Alpha to Beta]
MOVF,W Beta 'move contents of 'file' (ram location) I call beta to W (work reg)
SUBWF,W ALPHA 'subtract W contents from 'file' I call Alpha
BTFSS CARRY ' Bit Test flag(here, a carry), Skip if carry is set
GOTO CARCLEAR ' This instruction skipped if carry was set, else jump occurs
MOV..... ' IT was set, Alpha >= Beta
CARCLEAR ...... 'It wasn't zero, come to this label Beta > Alpha
-or-
[do..while_not_zero loop]
MOVLW .5 'move 5 (dec) into the tiny 'working register' (W)
MOVWF Index 'move contents of W into a 'file' register I've called Index
GUTS (label)
do something
DECFSZ Index 'decrement Index, skip if dec'ing caused the zero flag to set
GOTO GUTS loops back to guts if not zero
If you don't like jumping if true in PBASIC, you can alway test for a condition you know will *not* occur. You can use preprocessors, high level languages, and other artifice to get you away from the silicon (and don't the people love to), or you can have fun playing in the sand .
PBASIC language syntax WizardOfAz Programming 14 30-04-2003 10:23
Hints For Rookie Programmers Noah Programming 30 20-02-2003 20:07
Contradictory FIRST Statements Gobiner Rules/Strategy 10 14-01-2003 16:12
TechnoKat Robot archiver 2001 21 24-06-2002 00:28
Logical statements or math formulas Manoel Programming 1 16-02-2002 23:29
