Go to Post Good robots with bad drivers can lose. Bad robots with good drivers can win. Good robots with good drivers can dominate. - James Tonthat [more]
Unread 07-01-2012, 14:18
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Eclipse IDE for 2012 Java Programming
Has anyone found where the plugins for this are available? I've been through the WPI site as best I can without much success. I know that NetBeans is the preferred IDE (by WPI), but when I spoke to Brad about a month ago I thought they were still going to support Eclipse (I can live without the wizards).
Unread 07-01-2012, 15:27
CodeYeti's Avatar
CodeYeti CodeYeti is offline
FRC Addict
AKA: Matt Coffin
CodeYeti is an unknown quantity at this point
Re: Eclipse IDE for 2012 Java Programming
Well it doesn't look like the 2012 version of the plugin is available. At least I haven't been able to find it. The link for the provider is here if you wish to use the one from last year in the meantime or maybe wait for it to get updated.
http://first.wpi.edu/FRC/java/eclipse/update/stable/
If anybody has a link to an updated version, please shoot it this way; I'm in the same boat.
Unread 07-01-2012, 16:50
AKA: Brad
#0190 ( Gompei and the Herd)
Yeah... we've been focusing on Netbeans and added plugins to create command-based robot projects. We'll post a message later with the status of the eclipse plugins for 2012. I know it's not eclipse, but the Netbeans plugins are pretty nice.
Brad
Brad Miller
Robotics Resource Center
Unread 07-01-2012, 18:25
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Is it possible to use the netbeans plugin for eclipse?
Unread 07-01-2012, 19:21
AKA: Brad
Unfortunately, they are completely different formats between the two IDEs.
Brad
Brad Miller
Unread 07-01-2012, 19:54
Intel i7 Intel i7 is offline
Team Role: Driver
Intel i7 is an unknown quantity at this point
I found this but its from 2009, will it still work?
http://forums.usfirst.org/showthread.php?t=13487
Driver
Programmer
Webcoder/Designer
http://www.chiefdelphi.com/forums/showthread.php?t=102329
Making our own custom dashboard system/framework!
Unread 08-01-2012, 06:50
AKA: Stu
I agree the NetBeans plugins are very nice - but for various reasons we'd prefer to use Eclipse. I'm not asking WPI to create a parallel set of all the wizards, etc. for generating the new commands-based framework; just the basics of being able to build, deploy, and run an Eclipse robot project with the new library(s). Copy and paste to get the new classes in Eclipse will be fine. Thank you in advance!
Unread 08-01-2012, 10:39
AKA: Brad
No, no, it's OK to ask. We'll probably have a plugin up soon.
Brad
Brad Miller
Unread 09-01-2012, 23:05
Jeanne Boyarsky Jeanne Boyarsky is offline
Java Mentor
FRC #0694 (StuyPulse)
Jeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud ofJeanne Boyarsky has much to be proud of
If you just want to compile in Eclipse, you can have one person get the NetBeans plugin and copy the jar file elsewhere/distribute it to the team. Then your Eclipse project points to that jar. And the Ant script to build in Eclipse like in 2009/2010. Not as simple as a plugin, but should tide you over until it is ready.
Team 694 mentor 2010-present, FIRST Volunteer and Co-organizer of FIRST World Maker Faire Tent
2012 NYC Woodie Flowers Finalist
2015 NYC Volunteer of the Year
Unread 16-01-2012, 01:14
rthinman rthinman is offline
AKA: Rod Hinman
FRC #3881 (WHEAbots)
rthinman is an unknown quantity at this point
Brad,
Any update on an ETA for Eclipse plugins? Since we've used Eclipse in the past, that would be the easier path if we know it will be here soon. Just trying to plan. Thanks for all your hard work.
Unread 16-01-2012, 11:38
AKA: Brad
I've been watching checkins... hopefully soon, maybe today or tomorrow.
Brad
Brad Miller
Unread 17-01-2012, 16:38
Ryan O's Avatar
Ryan O Ryan O is offline
FRC Eclipse Plug-in Developer
no team (FRC Eclipse)
Ryan O is an unknown quantity at this point
Send a message via AIM to Ryan O
Hi everyone!
The plug-ins are ready for release! For details on how to properly set up Eclipse, see the document located at:
http://firstforge.wpi.edu/sf/docman/...tation/doc1303
Have fun, and good luck this year!
CRUD Name: Windows
Alumni to Team: 350
Unread 17-01-2012, 19:28
AKA: Stu
Ryan,
On behalf of everyone (wanting to) use Eclipse for programming FRC - Thank you very much for your efforts ... I can't wait to download the plugins and migrate back to Eclipse.
Stu
Unread 19-01-2012, 19:12
AKA: Rod Hinman
OK, so this sounds like a stupid question, but where is the cRIO image? As I understand it, the plugin is supposed to install the Java image. I have installed the Driver Station, LabView (I loaded LabView also) and Utilities updates.
When I run the cRIO Imaging tool and try to format the controller, I get an error: "No cRIO Images found. Expected here: C:\Users\Developer\sunspotfrcsdk\cRIO_Images" I presume that the Eclipse plugin would create and fill it, but that folder does not exist.
Just FYI, the imaging tool does find the cRIO and also finds the image for LabView, so that part of things appears to work.
Just thinking ahead, I suppose I could install Netbeans to get the image, then just continue to use Eclipse?
Thanks for any help,
Rod
Unread 19-01-2012, 19:20
AKA: Stu
There is no doubt a way to do it via Eclipse, but I have always installed NetBeans and run that first once just to get the image to flash the cRIO with ... especially since the Eclipse plugin always lags the NetBeans one after kick off.
