Go to Post Pizza tastes best after a few long hours of robot building. - Max Lobovsky [more]
Unread 07-01-2012, 14:31
Andrew Lawrence
Posts: n/a
Question about returning basketballs
From the picture, it seems like when your robots score basketballs into their goals (I think they are on the same side as the drivers, if not this question is invalid), the human players need to take the balls from the corral and travel around the field to the "alley" area for their team. Is this correct?
Unread 07-01-2012, 14:39
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Question about returning basketballs
it doesn't look like it. it looks like when your team scores the opposing alliance's human players get to introduce them back into the field...
Unread 07-01-2012, 14:40
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
Realize that the Blue alliance station is on the right, and they score on the left (from a certain point of view). That means the balls Blue score come out in the Red alliance zone, so Red returns them.
The Inbounders must IMMEDIATELY remove basketballs from the Corral (where the balls go after being scored) and must HOLD them, no more than two at any one time [G31]. So no setting the balls down, and each of the three Inbounders can only hold two at any time. Violation: Foul.
Unread 07-01-2012, 14:42
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
The inbounder is on the same alliance as the driveteam on his side, takes the ball out of the corral and puts it in his alliance's alley. (That's what it looks like in the animation at least.)
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 14:45
Austin2046's Avatar
from the first arena image it looks like you're alliance is scoring on the far wall from your alliance station. the balls your opponets score come to your alliance's coral and your human players introduce back into your alliance's alley.
Unread 07-01-2012, 15:17
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
According to the first image in The Arena section, correct. The game animation also supports this. All members of the Blue Alliance are on one side, and the members of the Red Alliance are on the other, and they stay there. Balls that you score go to your opponent's human players and are released into their alley.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 07-01-2012, 15:21
Andrew Lawrence
Posts: n/a
Thanks!
Unread 07-01-2012, 16:40
GCentola's Avatar
GCentola GCentola is offline
Strategical Tactitian
AKA: Garrick
no team (SparX)
GCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud ofGCentola has much to be proud of
So the question becomes how do you think this will affect scoring? When one alliance scores, the other alliance has the potential to score those balls. Will it increase the score? Will it make scoring quickly less optimal? What do you guys think?
GO SparX on 3!!!!!
Check us out at:
http://www.gosparx.org
http://www.facebook.com/SparX1126
I Love Two Pencil Designs!
Unread 07-01-2012, 16:45
Sean M's Avatar
FRC #0830 (RatPack)
Well, they can't directly score, they have to put the ball back in play (not throwing it until the last 30 seconds) from which it's still up to the robots picking it up and crossing the field to score it. Is that what you mean?
Unread 07-01-2012, 16:57
GCentola's Avatar
AKA: Garrick
no team (SparX)
I mean when the blue alliance scores, it puts balls in the red alley. Do you think that will make a significant difference?
GO SparX on 3!!!!!
Check us out at:
Unread 07-01-2012, 17:17
Sean M's Avatar
FRC #0830 (RatPack)
I think it's good. Imagine that instead of going to, as you put it, the Red team it instead goes to Blue. Blue just scored, so they got points AND control of the ball.
Most games don't work this way (sports and, in our case, Rebound Rumble) because that gives two perks to someone scoring. Because the ball goes to Red, they will likely want to put the ball back into play for a chance to score it for themselves. They could also choose to hold on to it for a while, if desired.
It's like a flashback to Breakaway in 2010, where the goals were also opposite of your alliance station.
In my opinion it's better, and keeps the game moving.
Unread 07-01-2012, 17:50
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
The way I see it:
Since the opposing alliance is required to take balls from the corral immediately and then each inbounder can only hold on to two balls at a time, you could be in a situation where if you score fast enough more than six balls are scored before any are inbounded. This would mean that the inbounders MUST put some balls into play regardless of whether or not their alliance can retrieve the balls right away, leaving them possibly where robots from their opposing alliance could get to them first and score them.
This is a possibility if you can score fast enough to force this situation. With only 18 balls and the rule about carrying only up to 3 at a time, this may be extremely difficult, but it could happen!
Only hole in this logic...what if the inbounders can juggle???
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 07-01-2012, 21:09
Ninja_Bait's Avatar
AKA: Jake Potter
Then they aren't holding the balls.
Unread 07-01-2012, 21:16
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Check out the link below for a video that FIRST has put out in a series to give an overview of the field. I hope this helps!
http://www.youtube.com/watch?v=IaFiCbZLPRY
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 07-01-2012, 21:21
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
[G31] states that Inbounders may hold a maximum of two balls, and the balls must be returned immediately upon arrival to the corral. Juggling the balls would break that rule.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
