Go to Post since when is not sleeping, caring more about the robot and such bad for you? If it is how come I didn't get the memo? :ahh: - Sakura141 [more]
Unread 07-01-2012, 14:29
shaharsss1690's Avatar
shaharsss1690 shaharsss1690 is offline
AKA: shahar
FRC #1690 (Orbit)
shaharsss1690 is an unknown quantity at this point
Robot exceeds frame perimeter
Can our Robot exceed the frame perimiter?
Our team didn't really understand since under <R02> \ E it says: "no other part of the Robot may extend beyond the vertical projection of the Frame Perimeter (with the exception of minor protrusions permitted per 0)."
This stands in contrast to ,<R02> \ D, but what did the manual mean by "any appendage"?
This seem to limit what we can do in the game as a whole, how can a robot even get the bridge to tilt if we can't extend beyond the bumpers?
Please enlighten us!
Unread 07-01-2012, 14:35
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
Re: Robot exceeds frame perimeter
Look at part D. to [R02]:
"any appendage may not extend more than 14 in. beyond the frame perimeter, and"
which is followed immediately by part E.:
"no other part of the robot may extend beyond the vertical projection of the frame perimeter..."
Where the "no other part" references the appendage in part D. In other terms, you can have one appendage which may extend no more than 14 in. beyond the frame perimeter out at any one time.
If you have two appendages, they can't both be out at the same time, even if they are less than 7 inches out (summing to be less than 14 in.).
Unread 07-01-2012, 14:48
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
and of course the horizontal distance from the front of the fender to the front of the rim is 14.25''... plus the width of your bumper... so it looks like there's no dunking.
Unread 07-01-2012, 14:50
Sean M's Avatar
FRC #0830 (RatPack)
Or at least no direct dunking, but you can most definitely close the gap to within about 3 inches...the trouble would be having others bump into you.
Unread 07-01-2012, 15:15
tapdancingstef tapdancingstef is offline
FRC #2531 (StormHawks)
tapdancingstef is on a distinguished road
So does this include the height dimensions? Meaning that the maximum height is really 74 inches in the alliance station and 98 elsewhere on the court?
___________________________
Mentor, Team 2531 and 1816
Unread 07-01-2012, 15:24
Sean M's Avatar
FRC #0830 (RatPack)
The maximum height is 60" to start [R02], but may extend to 84" tall once the match starts (as long as your robot is not on your opposing alliance's half of the court), [G20].
The 14" is for being OUTSIDE your Frame Perimeter and it's vertical projection.
Unread 07-01-2012, 16:18
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
What that rule is for is mushroom bots my team had to add on to our frame last year becauseour gear guard stuck out past our frame. Appendages can only stick out14inches though.they just don't want a robot with stuff sticking outside the frame causing a safety hazard
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 07-01-2012, 16:21
Sean M's Avatar
FRC #0830 (RatPack)
I'm sorry, what do you mean? What rule?
And yes, we covered this (in the aforementioned rules).
Unread 07-01-2012, 16:26
AKA: carroll
R
I mean the rule the question was first about RO2
Unread 07-01-2012, 16:30
Sean M's Avatar
FRC #0830 (RatPack)
Hmm. I see. [G21] also states that only one appendage may be deployed at any time. But good point.
Unread 08-01-2012, 18:00
Mik_951 Mik_951 is offline
Coordinator
FRC #3360 (Hypérion)
Team Role: Communications
Mik_951 is an unknown quantity at this point
Hi! In the rule G20, they say: ''Robots in contact with the carpet on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.'' and so, what place do they mean when they talking about the carpet on they Alliance Station end of the court.
Thank!
P.S.: I'm not talking in english so sorry if there is mistakes!
Unread 08-01-2012, 18:05
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
It means that the robot cannot be above 5' when it is on the half of the court closest to its alliance station, but can be up to 7' on the other half.
Basically, you have to be short when you're defensive, but you can be tall when you're offensive.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 18:06
For anyone still confused about the description "mushroom bot", it refers to a robot that's designed to have a drivebase smaller than the maximum legal size but have parts above the base extending out to the maximum allowed dimensions. It was a phrase used the first year bumpers were mandatory, as an example of something that didn't obey the rules. The primary intent of the bumpers is to have only bumper-to-bumper contact between robots.
Unread 13-01-2012, 16:26
dsirovica's Avatar
dsirovica dsirovica is offline
Programming and Electrical Mentor
AKA: Dean Sirovica
FRC #1458 (Red Ties)
dsirovica is on a distinguished road
(1) Can we have two arms to push down the bridge, especially if another robot is on it already, for stability reasons? (2) what if a drive shaft links the two arms - would that count as ONE appendage - as it is one mechanism.
I wonder?
Dean
Unread 13-01-2012, 16:37
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
I wonder?
Dean
I would say as long as one shaft, or gears and chains connecting multiple shafts is driving both, I'd say it's one appendage.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
