Go to Post Well... as ready as we can be 30 days before build season... We definitely do not have a robot yet though... :) - pandamonium [more]
Unread 07-01-2012, 14:55
savetheworld17 savetheworld17 is offline
AKA: Megan
FRC #2067 (Apple Pi)
savetheworld17 is an unknown quantity at this point
Climb up the fender?
Hi all, I was wondering if anyone had any insight on whether it would be possible for a robot to climb up and/or attach itself to the fender.
According to the game manual, its purpose is to "protect the hoops from damage done by robots," and the robots also cannot damage any part of the field. Also, the fender "measures 8-1/4 in tall at the front, and 10-1/4 in tall at the back against the Alliance Wall," meaning that it is curved, so it would definitely be difficult to do. Moreover, in [G11] it states "Robots may not become entangled in the Arena elements."
However, it would take a lot of the aiming out of scoring baskets if you could climb up onto the fender.
Any thoughts?
Thanks!
Unread 07-01-2012, 14:57
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Climb up the fender?
The fender is underneath the hoops and prevents balls from getting stuck in that corner.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 15:09
AKA: Megan
Okay, so I'm guessing that would mean the if you did not make your basket, the ball would likely hit your robot.
But just because it is meant to prevent hoops from being damaged by robots, does that explicitly prevent robots from climbing it? I'm guessing that would defeat the purpose of the fender. I just brought it up because there was no rule I could find prohibiting climbing up onto it.
Also, you could also potentially get the ball stuck in that corner too if the robot climbed up onto the fender, defeating its purpose also.
Thanks for the response, by the way
Unread 07-01-2012, 15:38
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
There are no rules that explicitly disallow contact or climbing on the Fenders, or contacting the Hoops, as far as I can tell...although, I would expect some clarification or ruling on this to come out with a Team Update or in Q&A...with their purpose being to protect the Hoops, I would personally discourage climbing on the Fender.
I don't see what you mean about a ball getting stuck in "that corner?" If you climb up on it and block a ball that has rebounded (note, missed the hoop -- if a ball goes through the hoop, it goes into the Corral), it will be released as soon as you move off the Fender.
Unread 07-01-2012, 15:41
AKA: Megan
Okay, thank you.
I agree, I don't think it would be wise to climb up onto the fender, because not only could you damage the hoops, but it is on a slant and it would be very difficult to climb up for not much advantage. Plus, you wouldn't be able to use the sensors to shoot and it'd be a very difficult angle for shooting at.
And by being stuck in that corner, I meant if the robot was still on the fender. The robot blocking the ball would be the only way it could be stuck.
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
That is good to know
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
cbeavers6790's Avatar
cbeavers6790 cbeavers6790 is offline
AKA: carroll
FRC #3542 (Team S.P.E.E.D)
cbeavers6790 will become famous soon enough
Cant quote exacts but I would not advise climbing on the fender if you look at G(10) in the game section it gives you more specifics.g11 also says you are not allowed to become entangled in arena elements.
IM THE ENFORCER OF ALL RULES (at least the ones in the manual)
Unread 07-01-2012, 15:42
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
What would you do if you missed a shot, and the ball ended up below the hoops? There would be a high risk of entanglement in the net if you were to try and retrieve it. The fender seems to be there to prevent that problem: if you miss a shot, the ball will bounce or roll off the fender, so you don't have to try and navigate around the nets to try and retrieve it.
While there aren't any rules (yet) that prohibit climbing on the fender, I wouldn't suggest it.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 07-01-2012, 15:53
GaryVoshol's Avatar
Cogito ergo arbitro
The field drawing shows the fender is only made of 1/2" plywood. Deliberately climbing on it would result in severe risk of damaging it, in my opinion. Potential disablement per [G12].
(since 2004)
Unread 08-01-2012, 14:10
AKA: Megan
Okay, that makes sense.
Question: what about a part of your robot utilizing the fender? Instead of having your entire robot climb up it, you can have a part of your robot attach to the fender to shoot.
As long as this part isn't that heavy to prevent damaging the fender, I can't see anything to prevent this.
Thoughts?
Thanks for all the input everyone! I really appreciate it
Unread 08-01-2012, 15:35
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Thoughts?
[G10]
Robots may not grab, grasp, grapple, or attach to any Arena structure. (Robots may push or react against any elements of the Arena that is not protected by another rule.)
Violation: Foul
you can't "attach" to plywood w/o grabbing it in some say... you can drive up to it but that's all you can (legally) do.
