Go to Post Sometimes it's not what you know going into a battle, but who you know. - Elgin Clock [more]
Unread 07-01-2012, 15:23
KaraW's Avatar
KaraW KaraW is offline
FRC #1318 (IRS)
Team Role: Electrical
KaraW is an unknown quantity at this point
Game Ramps
A couple people on our team were looking threw the rules and the list of field parts trying to figure out what material the ramps were made of. Does anyone know?
Unread 07-01-2012, 15:28
The Reaver The Reaver is offline
FRC #2840
The Reaver is an unknown quantity at this point
Re: Game Ramps
I had a different question that could probably be answered in this thread. Do the ramps immediately swing back to the neutral position when they are tipped to one side, or do they stay tipped?
Unread 07-01-2012, 15:29
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
Re: Game Ramps
See Section 2.2.5: "Each Bridge is mounted on a double-hinge that allows the Bridge to tip towards either end of Court."
Unread 07-01-2012, 15:30
FRC #2840
Re: Game Ramps
That doesn't answer my question, though. I know they can TIP to either end, but I don't know whether they STAY tipped.
Unread 07-01-2012, 15:31
Sean M's Avatar
FRC #0830 (RatPack)
Re: Game Ramps
That is all they say about the bridges; I would assume the double hinge would be naturally flat but that is a good question that should be clarified in Q&A.
Unread 07-01-2012, 15:32
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: Game Ramps
The ramps at our kickoff field always returned to the flat position.
Unread 07-01-2012, 15:33
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Game Ramps
It's not in the rules - you need to check the drawings and field specs for materials and official dimensions.
From the Game Specific Drawings PDF (I'd usually tell you to look harder, but the field drawings are nasty to look through):
"Note: Material to be 1/2" thick HDPE in blue, red or white."
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 07-01-2012, 15:51
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Game Ramps
Our team is wondering this too: Can someone who went to a kickoff event enlighten us on the details of the field?
Particularly if the bridge stays down or if it returns to level. More that one person confirming this would be appreciated.
Unread 07-01-2012, 15:54
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Re: Game Ramps
The bridge at our kick off (MN) also returned to level.
Unread 07-01-2012, 16:05
KaraW's Avatar
FRC #1318 (IRS)
Re: Game Ramps
Thanks! So it appears the ramps are made of High-density polyethylene.
Unread 07-01-2012, 16:11
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Game Ramps
There are no ramps; there are Bridges. Just sayin', in case you want to search the rules.
For those at Kickoff sights that reported here, were those official field elements or team-build field elements? They may act differently because of different materials.
(since 2004)
Unread 07-01-2012, 16:17
AKA: Kara Bakowski
Re: Game Ramps
I should probably clarify - I think I read the original question wrong. The top surface of the bridge is the HDP. The rest of the bridge is aluminum. If you're looking for further specs, check out the field drawings starting at GE-12017.
If you're asking about the fenders (ramps on either end of the field below the baskets), those are made of plywood.
Kara Bakowski
WMWBS '10 '11
Unread 07-01-2012, 16:26
Captainawesome's Avatar
Captainawesome Captainawesome is offline
FRC #2073 (EagleForce)
Team Role: Communications
Captainawesome is an unknown quantity at this point
Re: Game Ramps
It says that the bridge deck (Item 1 on the game Specific Drawings) is made of HDPE. The bridge surface (Item 4 on the game Specific Drawings) is above that and is only described as "bridge surface." I'm stil wondering if that is also HDPE or something different.
UPDATE: The bridge surface is CLEAR POLYCARBONATE.
Unread 07-01-2012, 16:28
ThaneS ThaneS is offline
FRC #0167 (Children of the Corn)
ThaneS is an unknown quantity at this point
Re: Game Ramps
Actually, I believe the top surface is clear polycarbonate. The drawing for it (Bridge Surface, GE-12095) is separated from the rest of the bridge drawings. It lies above the HDPE (Bridge Deck, GE-12018), as shown in the Assembly drawing (GE-12017). Ah, the joys of a hundred pages of technical drawings.
Unread 07-01-2012, 16:29
caffel caffel is offline
AKA: Charlie Affel
FRC #0423
caffel is an unknown quantity at this point
Smile Bridges, Arena 2.2.5
We have several members who will swear that the bridge was described as 'tri-stable' at the kickoff.
I agree w the correspondents on this thread that it is an important point.
This doesn't seem to be covered by the rules.
We will be asking this as a question when they get around to opening up the QA system on the 11th.
Charlie Affel,
Mentor 423
