#16
Re: 2012 Catalyst Simulator question
I downloaded it and try to run the program, but now it says I am not using the correct password when i launch the program. I have even changed the password to make sure i didnt have an error in it.
#17
Doesn't support Canadian teams on the registration page, I'm going to have to e-mail them.
Also, does the simulator allow for importing models for robots from other programs? |
#18
Are you using Team**** as your username? |
#19
To the second part, no. This feature is not supported |
#20
I'm getting the error "You are already logged into another computer. Please log out of that computer and try again." I've been having this problem for over a half hour.
#21
My mentor gave me the download Ill upload it later tonight for others to use.....
#22
Yes I am using the correct username. The program doesnt allow for capitals which was required of the password and username during setup.
#23
I just got it figured out. You can not use the caps lock, you must use shift when entering your login ingo or else it doesnt work correctly.
#24
We recommend that you do not do this. You will have to register with our website (dbsgames.net). Therefore, uploading the exe file will allow for install, but each team must have individual log in information in order to play simultaneously.
#25
Thanks for the reply. No dual monitor setup here, but specs if they help:
Windows 7 Pro 64 3.4 GHz i7-2600K 8GB RAM Nvidia GTX 480 And I continue to get the "already logged in" error. The one time it did not give me this error, the application crashed when logging in, then resumed giving me the "already logged in" message. There were some details about its crash, but I neglected to write them down. I'll try and do that if it comes up again. As for the crash when clicking off - it only happens when I have switched to another window and been there for some time. If I click out and then immediately click back in (<15 seconds), it does not crash. EDIT: more info on the crash, not sure if it helps at all... Problem signature: Problem Event Name: CLR20r3 Problem Signature 01: first game.exe Problem Signature 02: 1.0.0.0 Problem Signature 03: 4f0651d3 Problem Signature 04: FIRST Game Problem Signature 05: 1.0.0.0 Problem Signature 06: 4f0651d3 Problem Signature 07: 2ca Problem Signature 08: 6 Problem Signature 09: System.NullReferenceException OS Version: 6.1.7601.2.1.0.256.48 Locale ID: 1033 Additional Information 1: 0a9e Additional Information 2: 0a9e372d3b4ad19135b953a78882e789 Additional Information 3: 0a9e Additional Information 4: 0a9e372d3b4ad19135b953a78882e789 Last edited by playbass06 : 07-01-2012 at 14:52. |
#26
I am Living in ISRAEL Doesn't support teams on the registration page
#27
Idid it |
#29
Can students make accounts, or just mentors? If not, will there be a way for team members to be on different computers using it?
Oliver |
#30
The only information we verify is the team number, city, and state (or equivalent). Students or Mentors can create the account. Also, you can download the game to as many computers as you would like. However, you will only be able to play with your team's account on one computer at a time.
