Go to Post The only shame is if you are too proud to ask for help and to learn. - Mc Kenna [more]
Unread 07-01-2012, 15:18
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
USB came in corrupt :(
Our USB with the latest FRC image for the classmate appears to be corrupted. We backed up our classmate and then booted the classmate from the USB by changing the USB device to 1st priority boot order in the BIOS.
The computer gives us a disk read error. Anyone have a clue what's going on or has the same problem?
Also, if possible could someone upload the uncorrupted files that are supposed to come on the USB.
Edit:
We disabled all the other boot devices and disconnected all pripherals other than the USB and still receive the same error
We have the first classmate (E09)
Unread 07-01-2012, 16:00
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: USB came in corrupt :(
Same here. So much for hitting the ground running.
Unread 07-01-2012, 16:19
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
We receive the same error with ours: "A disk read error occurred". (2009 Classmate)
Unread 07-01-2012, 16:24
FRC #1747
Yeah we are using a 2009 Classmate as well, no clue if it would work with the 2011 classmate
Unread 07-01-2012, 17:22
ayeckley's Avatar
ayeckley ayeckley is offline
AKA: Alex Yeckley
FRC #2252 (Mavericks)
ayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond reputeayeckley has a reputation beyond repute
[Edit] I thought we were discussing the NI LabVIEW USB stick - I just realized that this thread is specific to the Classmate re-imaging process. My bad...
Unread 07-01-2012, 17:32
TheMaster TheMaster is offline
FRC #2605
TheMaster is an unknown quantity at this point
Same here, we also have a 2009 classmate and the same error message.
Unread 07-01-2012, 17:41
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Same here. Not likely to be USB 3 related as even if it is a USB 3 capable key, USB 3.0 is backward compatiable with USB 2
Unread 07-01-2012, 18:12
ayeckley's Avatar
AKA: Alex Yeckley
[Edit] I was trying to solve the wrong problem...
Unread 07-01-2012, 18:39
DavidGitz's Avatar
DavidGitz DavidGitz is offline
Lead Technical Advisor
FRC #1208 (MeTool Brigade)
DavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud ofDavidGitz has much to be proud of
Send a message via AIM to DavidGitz Send a message via MSN to DavidGitz Send a message via Yahoo to DavidGitz
Our Team has the same problem.
Unread 07-01-2012, 18:40
FRC #1747
Originally Posted by ayeckley View Post
It would not shock me if that gadget is not fully USB3.0 compliant. All I know is that I got a read error on my older USB 1.0 and USB 2.0 machines, but was able to read on the first attempt on a machine that has USB 3.0. YMMV...
Well from my knowledge anyone with this problem seems to have been when using it on the classmate 2009. Since you are using a different machine it is highly possible that you could be right. I don't know much about the differences between usb 3.0 and 1.0 other than speed so I wouldn't know the answer for that. I'm curious to see if anyone is having the same problem if their using the stick for the classmate 2011
Unread 07-01-2012, 18:43
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Look here:
http://www.usfirst.org/roboticsprogr...driver-station
Unread 07-01-2012, 19:06
Exe_Arco Exe_Arco is offline
FRC #2993
Exe_Arco is an unknown quantity at this point
To the fellow people having difficulty with this issue, it seems as if many people are having this problem.
However, two members of our team have found a solution for the current problem.
Use the Image on the USB Drive on another computer to boot to the Installation process. Then shut down the computer and then put it into the classmate.
  • Note I really doubt that this will work on every machine as we are STILL questioning why this is working on ours. However, it matters not as it seems as if Classmate 09's are having all of these problems.
Note, this only fixes one part of a massive problem. Then after you install it on your classmate, all It does is re-boot with out the wizard.
We have NOT found a way around this and is where our current problem with this is happening.
Unread 07-01-2012, 19:08
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
We're having the problem too, I've seen several others fighting with this. They all had the old classmates. About 4 of the 7 teams I saw got it fixed with another team's image, but this hasn't worked unilaterally. The above link is really helpful.
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 07-01-2012, 19:36
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
Team Role: Electrical
There were 2 USB's given out, or at least there was supposed to be, ones that said E09 and E11 on it. If you have a classmate from 2009 you need the E09 USB.
2012-2016 Wave Robotics Team 2826
Unread 07-01-2012, 22:23
aeasson aeasson is offline
FRC #2435
aeasson is an unknown quantity at this point
Team 2435 had a 2009 Classmateand the E09 stick gives us the same error.
I inserted the stick in an old WinXP laptop and it made it to the image menu.
I did not want to reimage thje laptop so I cancelled at that point.
But, at least the stick did not give the read error immediately.
