Go to Post Defense shall reign supreme. - Corey Balint [more]
Unread 07-01-2012, 17:50
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Question about returning basketballs
The way I see it:
Since the opposing alliance is required to take balls from the corral immediately and then each inbounder can only hold on to two balls at a time, you could be in a situation where if you score fast enough more than six balls are scored before any are inbounded. This would mean that the inbounders MUST put some balls into play regardless of whether or not their alliance can retrieve the balls right away, leaving them possibly where robots from their opposing alliance could get to them first and score them.
This is a possibility if you can score fast enough to force this situation. With only 18 balls and the rule about carrying only up to 3 at a time, this may be extremely difficult, but it could happen!
Only hole in this logic...what if the inbounders can juggle???
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 07-01-2012, 21:09
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Then they aren't holding the balls.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 21:21
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
[G31] states that Inbounders may hold a maximum of two balls, and the balls must be returned immediately upon arrival to the corral. Juggling the balls would break that rule.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 07-01-2012, 21:35
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
There are two possibilities: Juggling is an exception to this rule or you may not throw balls to eachother.
Only Inbounders may contact Basketballs; each Inbounder may hold a maximum of two Basketballs. During Teleop, Inbounders must remove Basketballs from the Corral immediately upon arrival. All Basketballs in the Alliance Station must be held by Inbounders once removed from the Corral.
Unread 07-01-2012, 21:36
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I'm rather glad of this new design. It breaks the large possibility if it were the opposite way of a 469-style 2010 repeat.
Attending: MN Duluth Regional
Unread 07-01-2012, 21:37
pfreivald's Avatar
AKA: Patrick Freivald
Indeed... This means that some rapid scoring and floor ball pickup could result in a serious advantage in-game.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 21:39
AKA: Simon Bohn
But you have to work together with your alliance to score in multiple hoops in quick succession to make this viable.
Unread 07-01-2012, 21:51
pfreivald's Avatar
Indeed! Or not, if your opponent doesn't have a designated ball-distributor!
Team 1551
I write books, too!
