Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 07-01-2012, 18:54
giantmidget31's Avatar
giantmidget31 giantmidget31 is offline
Eat robots, build waffles.
FRC #0555 (Montclair Robotics)
Team Role: Electrical
giantmidget31 is an unknown quantity at this point
Using a Flex Sensor
My team wants to integrate a flex sensor into our driver station controls. We were thinking using an Arduino might work but we really don't know how it would be done. Any help would be appreciated, in particular interfacing the information the Arduino would put out (flex sensor values) with the driver station.
Unread 07-01-2012, 19:23
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Using a Flex Sensor
You could just wire the flex sensor directly to the IO Board, and read the values from that, no need to interface between the Arduino and the cRIO.
Unread 07-01-2012, 19:43
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
From my experience, flex sensors are incredibly unreliable -- not in the respect of reading, but more in interpretation of what a certain reading means.
The flex sensors have so many different ways to bend (providing ambiguity in what a certain reading actually means), that if you are going to try to use them for much more then binary calculations (Am I touching something?) it's probably going to be difficult to get to work, if it does.
I would imagine that you're not going to use flex sensors for wall following or the sort, but just something o keep in mind if you've never worked with them before.
Unread 07-01-2012, 22:26
I want to use the flex sensor as part of a controller, not on the robot.
Unread 07-01-2012, 22:31
G33K's Avatar
G33K G33K is offline
Professional Baller
AKA: Ethan Anderson
FRC #0100 (The Wildhats)
G33K is on a distinguished road
I believe most flex sensors, if not all, act as variable resistors giving analog values. In this way, you'd wire the flex sensor into one of the analog inputs on the Arduino. The Arduino has an analog-to-digital converter on-board and you can program it to "write" those values through the USB port via serial interface. If for some reason you are unable to or don't want to use the 0-1023 numerical values the Arduino reads from the analog ports, you can always map them to different values or really do whatever you want with them.
Unread 08-01-2012, 17:05
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
What exactly is a flex sensor, as in what purpose would it serve better than another sensor?
Unread 12-01-2012, 21:14
BAM BAM is offline
FRC #2425
BAM is an unknown quantity at this point
Flex sensor to Arduino is just an analog input. There may be some "Analog read" sample code, but if not, writing your own is not difficult. Arduino reference is very helpful, and the info on the analog read command can be found here:
http://arduino.cc/en/Reference/AnalogRead
If you give me some more information, I would be able to write the code for you. All the best,
-B
Unread 14-01-2012, 10:45
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
If any of you know instructables.com, I was looking through it one day and came across this:
http://www.instructables.com/id/Ardu...matronic-Hand/
Now I know you can't use the wireless part, but you may be able to use the concept.
Hope this helps.
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
