Go to Post Looks like it will be to your advantage to keep the Refs happy. Remember, Donuts go a long way toward that end! - billbo911 [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2012, 20:21
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: HiGrip wheel
They look sweet. The good old drag across the carpet test showed they were quite grippy. But we most likely wont use them because they are only 6in diameter wheels making getting over a 4 in bump quite iffy. But I like them very much and hope they will make other sizes soon.
Every day is a new adventure!!!
Unread 07-01-2012, 20:44
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: HiGrip wheel
One of our mentors thought they looked like LEGO wheels.
I agree with Jacob; maybe we'll wait for next year.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 19:48
penguinfrk's Avatar
penguinfrk penguinfrk is offline
AKA: Larry
FRC #1899 (Saints Robotics)
penguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of lightpenguinfrk is a glorious beacon of light
Re: HiGrip wheel
The HiGrip wheels seem nice. They're lighter than the 6" plaction wheels on AM by 38% (.5lb each as opposed to .81lb).
A google search for TPU Rubber wheels went nowhere. Is there any indication that it will be offered in larger sizes? Smaller sizes?
Larry
Saints Robotics 1899
High school intern at FIRSTWA
2011 Seattle Olympic Regional:
Website Excellence, FIRST Dean's List Award (for team captain Kevin Kimura), Tournament Winner (Thanks 3393 and 2990!), Chairman's Award Winner
Unread 08-01-2012, 20:05
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: HiGrip wheel
The size of the wheel does not necessarily keep you from going over the bump. Just build a slippery ramp in your chassis in front of your wheel so you slide up and over. That being said, we are using 8 inch wheels.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 08-01-2012, 20:34
Billfred's Avatar
Billfred Billfred is offline
Re: HiGrip wheel
We played with them a bit. I'm not certain that they'll see use on 2815's robot this year (in COTS or modified form), but they do look like an upgrade over prior designs with the divider as it is.
Teams I've been on have used variations on modern kit wheels for several years with no issue on the spokes. If we chose another wheel, it wouldn't be on that.
Unread 07-04-2013, 22:30
PhantomPhyxer PhantomPhyxer is offline
FRC #2643
PhantomPhyxer is on a distinguished road
Re: HiGrip wheel
Our Team was in two Regionals one at Medera, CA, Central Valley Regional and the last in San Jose, Ca, Silicon Valley Regional. Our 6' HiGrip KOP Wheel worked great in the first regional. While we at the second Regional the Janksters, Team 1976 reported that they had a wheel failure and ask us to borrow a wheel. However, we did not have a spare wheel. We took a look at our wheels and fould a broken spoke on a rear wheel. Upon further investigation we noticed the wheel was split across the tread. We did not have enough time to change this wheel until the next match. Thank you 2144 for giving us a wheel. The Janksters broke two wheels at SVR. I will not use these wheels next year.
Unread 07-04-2013, 22:36
Re: HiGrip wheel
Have you contacted AndyMark? Inform them of the problem (pictures should help), and hold off on declarations of not using the wheels next year until AM has had a chance to look into why they are failing. You're not the only team with these failures, as you know. AndyMark likes feedback, and likes to fix problems with their products promptly.
And two competitions on a single set--back when I was a student on a team, we could go through two sets of AM and McMaster wheels in an event, minimum one set. We'd usually take some time on practice day to change out from the previous event, wear through the wheels by the end of elims if not before, go to the next event, repeat. (We'd also buy quite a few spares.) You guys put a ton of drive time on those wheels, so I'm not terribly surprised that they would have broken eventually--fatigue plus impact will take down quite a few things, let alone a wheel.
Unread 07-04-2013, 22:51
FRC #2643
Re: HiGrip wheel
Thanks for the quick response. Like I said two teams at SVR had problems with these wheels. Our team 2643 and 1976. Team 1976 was paired with 254 and 118 to win SVR. But they broke two wheels. Yes, I am waiting to hear from Andy Mark. These wheels seem to be pretty grippy. But I think the drive train can over power the cross section.
Unread 08-04-2013, 04:13
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Re: HiGrip wheel
It was 1967 that had suffered the wheel failures, the wheels survived CVR without a problem, the students then added an extra pair of cims (4 total with the kit bot transmission), and added a little more defensive components that moved the CG up slightly. This caused a more hoppy robot, which also got into a few serious pushing matches. We actually broke 3 wheels throughout the event, one being last year's high grip that another team had loaned us. I don't think the wheels were bad, just didn't survive the abuse we were putting it through...
Here is an example...
http://youtu.be/048HHG8m6A0
Thanks to the 3-4 teams that loaned us wheels (the team didn't think the wheels would break and didn't pack any extras), including 692, 3933, 3482?, and others!
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 08-04-2013, 15:10
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
Re: HiGrip wheel
We broke 5 at the Sacramento, Andy Mark replaced them. Had no problem at CVR. We did get hit pretty hard when a nameless team ram us as we were tipping over. They have some bad reviews on the AM site.
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 08-04-2013, 15:20
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: HiGrip wheel
During the past two weeks, 3 teams have contacted us regarding some durability problems with these wheels. I have recently talked to one team today who had broken wheels at SVR. This is the same wheel that was used in 2012, with the same HiGrip tread. The only difference is that the tread is colored white this year. In 2012, we did not receive complaints regarding the durability of these wheels.
From my experience at regionals this year, there is much higher speed being reached by the robots in this open playing field. Robots are hitting each other at high speed within the field, and there are not field barriers (steps, etc.) present to slow them down. During these collisions, the wheel is getting a high side load. Combine this side load with a high tractive force of the wheel, and we have high stress on the wheel bore, spokes, and rim.
We have a short term and a long term plan to fix this wheel.
  • Short term: We suggest putting some 2-part epoxy in the area immediately outside of the bearing bore rim, in the pockets next to the screw holes. Putting a filler material in this area will help decrease the chance that the bore will break down.
  • Long term: We will improve the mold this summer for this wheel, beefing up the bore area, the rim, and the spokes. We may even try some other plastic co-polymers to see what has higher strength and higher impact resistance. Our current material is polycarbonate.
Sincerely,
Andy Baker
President
AndyMark, Inc.
Unread 09-04-2013, 11:24
dmulla dmulla is offline
FRC #1967
dmulla is an unknown quantity at this point
Re: HiGrip wheel
FYI, here's a picture of the wheels team 1967 broke at SVR.
The one on the right broke in match 28 and prevented us from driving. The middle one is not fully broken yet but has cracks on the spokes where they meet the outer rim so we replaced it. The one on the left broke in the elimination matches and we could still drive because every spoke completely broke so we were driving with 5 wheels.
Overall, we're very happy with the belt drive system, but this year we're able to drive much more aggressively than in the past due to the field and due to our robot having a much lower CG. So, while I think we've never seen anything like this (and we've used these wheels in the past), I also think we're abusing the wheels much more than in past years.
We're definitely considering metal wheels for next year already!
And, we're ordering spares for the championships (which we're VERY excited to be able to attend)!
