Go to Post Every team should have a rule about not shouting "ROBOT!" when transporting a robot around the pits/arena. - frasnow [more]
Unread 07-01-2012, 18:58
sand500 sand500 is offline
FRC #3540 (Wildcat Robotics)
sand500 is an unknown quantity at this point
Driver Station no longer has stop button?
When we took a look at the 2012 driver station, we realized that there was no space for the stop light like last year. Does this mean that stop light is no longer required? If so, maybe they did it so we could use that port for the Kinect, although the 2011 classmate has 3 usb ports where 2 of which go to the hub.
2 for joysticks, 1 for usb drive, 1 for kinect.
I think the stop button is more important for us during the build season because the robot could do unexpected things. In the actual competition, they will have a stop button for us.
Unread 07-01-2012, 19:10
Re: Driver Station no longer has stop button?
The laptop's spacebar is now the estop button. The return key is the disable.
Greg McKaskle
Unread 07-01-2012, 19:43
Fuego247's Avatar
Fuego247 Fuego247 is offline
FRC #0247 (Da Bears)
Team Role: Electrical
Fuego247 is an unknown quantity at this point
The KOP has a red sticker with "STOP" in big black letters. I'm assuming you attach the sticker to whatever you designate as your stop button.
Unread 07-01-2012, 19:56
brndn's Avatar
brndn brndn is offline
AKA: Brandon
brndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nice
From manual, The Arena section 2.2.9:
"Emergency Stop (E-Stop) buttons for each Robot are located on the left side of each Player Station shelf."
Unread 07-01-2012, 20:00
I suspect that the getting started manual or one of the other manuals has suggestions for where to place the sticker. And it will also call out the new DS changes including the estop button no longer being used.
Greg McKaskle
Unread 07-01-2012, 20:28
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Beta tester here. The E-STOP sticker is intended for your spacebar.
It took our team a while to get used to hitting the enter key instead of the spacebar to disable...
Unread 10-01-2012, 05:02
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
The Estop buttons were a pain anyway. Disable is sufficient. We operated most of the time with the estop disabled. It was better to go through the extra steps on startup to disable it than to have to go through a reboot every time it was pressed.
I'm dissapointed that they made the spacebar perform an estop. It's too easy to hit by accident.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 11-01-2012, 19:46
biskin biskin is offline
FRC #1245
biskin is an unknown quantity at this point
Is there a way to change the stop key to some other keyboard key?
Unread 11-01-2012, 20:03
Alex Carrillo
You'll get used to it; we sure did. At first we made a lot of mistakes, but the pain of manually rebooting the robot again and again teaches one quickly
Not that I know of. My guess is that the answer is no, especially because they want anyone, including FIRST Volunteers or safety inspectors, to be able to instantly emergency stop your machine while testing in the pits if it is being unsafe. Making the spacebar a standard "e-stop" button would facilitate this.
