Go to Post if sleep is essential, then yeah, I'm in trouble. - Eria4044 [more]
Unread 07-01-2012, 20:28
MysterE's Avatar
MysterE MysterE is offline
FRC Team #3337
AKA: Coach Eiland
FRC #3337 (Panthrobotics)
MysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond reputeMysterE has a reputation beyond repute
Send a message via AIM to MysterE
Question from a Coach
Ok all -
Just of curiosity - is it mathematically feasible to create a shooter than can calculate distance/angle/etc of a shooter and have it accurately make shots? Can it be done or is it simply a pipe dream?
Thanks.
Coach. D. Eiland
Head Coach - Team #3337
Panthrobotics (Woodlawn HS)
2016: Bayou Regional WFFA Winner
2016: Rocket City Regional Judges Award
2015: Bayou Spirit Award, Bayou Chairman's Award, Bayou Dean's List Finalist (Danielle Massey), Bayou Volunteer of the Year Award
2014: Bayou Dean's List Finalist (Witni Widmeier)
2011: Bayou Regional Winner | Judges Award
2010: Rookie Inspiration Award
Unread 07-01-2012, 20:29
Andrew Lawrence
Posts: n/a
Re: Question from a Coach
It's possible. 100% possible.
Unread 07-01-2012, 20:31
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
I was thinking something along these lines, but the camera would only need to calculate distance. Then adjust a shooter to hit the selected basket at that distance. I have no idea how to do it, that's the programmers problem.
Every day is a new adventure!!!
Unread 07-01-2012, 20:38
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
It's entirely feasible. I spent a good part of today discussing with another programmer the best way to implement it - it's just some simple trigonometry in solving the triangle made from your shooter, the alliance wall, and the hoop.
Unread 07-01-2012, 20:39
Silver218's Avatar
Silver218 Silver218 is offline
FRC #1827 (Robo-Jackets)
Silver218 is an unknown quantity at this point
Does anybody know if the Kinect camera can be used to locate the reflective tape on the baskets?
Unread 07-01-2012, 20:49
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Originally Posted by MysterE View Post
Ok all -
Thanks.
Mathematically, optimistically and practically feasible. As long as the sensor system and filtering done on the sensors is reliable (slight challenge, as an image analyzer sub-routine might take a while to fine-tune), and the shooter mechanism has a low standard deviation in it's behavior (read: reliable in shot taking), it's a piece of cake to code a system that can do a bit of math and calculate the shot trajectory.
Attending: MN Duluth Regional
Unread 07-01-2012, 21:08
Greg McKaskle Greg McKaskle is online now
A white paper is or should be posted on the NI site before too long that explains some approaches to processing images.
There are a number of techniques for calculating distance, but the straightforward one is to use the known width of the target and the information about the camera lens optics. You can find the optics view angle on the Axis web site.
Basically, if a target width is known, camera resolution is known, and lens info is known, you can calculate distance pretty accurately to a target located at any of the heights.
Greg McKaskle
Unread 08-01-2012, 02:29
mesamb1's Avatar
mesamb1 mesamb1 is offline
AKA: Sam Bacon
FRC #1466 (Webb Robotics)
mesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nicemesamb1 is just really nice
Check the other forumns on the Kinect camera on the bot. not wise.
Axis works fantastic. Perhaps FIRST will be nice enough to include a sonar sensor in the kit of parts you could use to....
Unread 09-01-2012, 08:25
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
There should be a sonar sensor in the kit. I remember writing a new example for it.
Doug Norman
Unread 09-01-2012, 16:41
BlueNova's Avatar
BlueNova BlueNova is offline
FRC #2704 (Order 2 Chaos)
BlueNova is an unknown quantity at this point
Greg McKaskle
I currently have a SubVi in Labview that calculates the distance to an object based off its width, and the angles you are viewing its edges.
However, I don't currently understand the stuff about the camera optics.
To get the angle that the camera is viewing the object at, is it an ArcCos function?
(pretty sure ArcCos is the simple name for the inverse function of cosine)
"We're all nerds here, no need to be socially awkward"
"Oh, you want to know what I would do? I'd make a helicopter."
Once a FIRST Student, ALWAYS a FIRST Student
Unread 09-01-2012, 16:52
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Ok all -
Thanks.
The calculations, once derived (that's the hard part), aren't too difficult for a computer. I can't speak about sensing and programming, but having a reliable shooter is just as important, especially as you move away from the hoops.
Of course, the combination of correct kinematics, reliable sensors, and consistent shooter makes for a fairly difficult challenge. Lacking any part of that trio means you'll miss. A lot.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 09-01-2012, 17:00
If you want to post more information about your approach, I or another mentor should be able to help. Yes, ArcCosine is the Inverse Cosine, but that isn't enough information to say it is the correct function.
Greg McKaskle
Unread 09-01-2012, 17:30
BlueNova's Avatar
My approach to the triangulation is like you said. I declare the camera to be at (0,0), and I input the object's width, and the angles that the camera is viewing the right and left edges of the object at.
I can then calculate the coordinates of the object, and from that find the distance and angle required to hit it.
However, I don't know how to find the angle that the camera is viewing the object at.
I would imagine that the simplest way would be to take the position the object is on the screen (in relation to the center), multiplying it by some constant, and then putting that number through an ArcSin function.
I think this would get the angle that the object's angle in relation to the center of the field of view.
Basically:
ArcSin((Position on Screen - Center of Screen) / Screen Width) = Angle Object is viewed at.
If the camera was a typical FRC Camera found in the kit of parts, would this be correct?
Unread 09-01-2012, 17:45
I'm not following the approach you've laid out. Are you trying to determine the distance to the target, the height of the target, or the location of the robot on the field?
To review, sin(theta) is equal to (side opposite theta)/hypotenuse. This is of course only true for right triangles.
Can you draw a sketch showing the triangle and labeling what the points of the triangle correspond to?
Greg McKaskle
Unread 10-01-2012, 18:10
BlueNova's Avatar
I'm still new to the interface on chief delphi, so let me know if this didn't work.
I put some pictures up on my profile that describe what I am thinking.
Basically, I need to find Theta 1 and Theta 2 on the triangulation diagram somehow.
I would like to use some sort of vision.
However, I'm not sure what math is required to convert an image from a camera into the angle that the camera is viewing something at.
If you could explain that to me, or direct me to a site that does, it would be greatly appreciated.
