Go to Post Someone once told me, "A smart man learns from his own mistakes, but a wise man learns from the smart man's mistakes." . - Pavan Dave [more]
Unread 07-01-2012, 20:42
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Let's Talk About The Bridge:
Does anyone think an active balancing mechanism, like a moving heavy object, on the robot to balance 3 robots? My guess is, like most years, the majority of the robots will be around 120 lb and it would be relatively easy to balance one or two on the bridge. I had the idea of putting the battery and electronics on a platform that can be shifted from the front and back of the robot and anywhere in between to actively balance the robot. Having the weight shift back and forth instead of the actually moving the robot will be better when trying to squeeze 3 robots on the platform.
Any one have any objections to that? Relatively, it would only add a weight of a motor and the mounting. All the other weight will come from other necessary components such as the battery and other electrical components, perhaps even the shooting mechanism itself.
Unread 07-01-2012, 20:44
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Let's Talk About The Bridge:
It'll be a whole lot easier to just move the base at a slow speed then to actively shift the weight in your robot.
1058 PVC Pirates 2016 - xxxx
Unread 07-01-2012, 20:46
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Elaborate, what do you mean by move the base?
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
It would be very likely in your idea that the cord could get caught or yanked from the connectors. The battery alone could work well if nothing would tangle on its cord, but a dead weight (if the robot has weight allowance enough for it) would serve the purpose just as well. No math to back this up, but anything lighter than the battery may not be worth spending the weight or motors on.
Unread 07-01-2012, 20:47
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
... and an understanding of who will move and (more importantly) who doesn't move to get the proper balance
___________________
- Tennyson, Ulysses
Unread 07-01-2012, 20:48
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
I was thinking of a lead screw with a "nut" that was just a huge chunk of steel with a threaded hole. But I also agree with BrendanB, that just careful driver control can be sufficient.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
AKA: Brendan Browne
Instead of having a mechanism move, just have your driver move at an extremely slow speed.
Unread 07-01-2012, 20:49
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'll second Brendan. Why not just move the whole robot instead? You presumably already have that system on your robot and working. Why make even more work for yourself when you already have a shooter, pickup, and bridge slapper to design and build?
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
I've thought about the battery connector, since the electronics are on the platform with the battery, that would be fine. But the cords for all the other components to pose a threat, but isn't that black plastic, snake like thing, for exactly this application?
Unread 07-01-2012, 20:51
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Thought about actively balance the bot that way, it is a viable option for 1 robot on a platform, but with 3, it gets really tricky because there simply is no room to move.
Unread 07-01-2012, 20:53
AKA: Brendan Browne
The only way you are fitting three is with 3 robots that are at least 28 inches wide and you'll have 11 inches of overhang at best.
Unread 07-01-2012, 20:55
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Believe me, a 38"wide robot can be valuble in the elimination rounds
___________________
- Tennyson, Ulysses
Unread 07-01-2012, 20:57
AKA: Brendan Browne
That's what we were thinking too but everyone on your alliance needs to think that way in order to get that bonus!
In the eliminations how does the coopertition bridge play out? I can't find that anywhere.
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I am wondering how robots are going to make the bridge go down form the neutral position. That may be hard. Is it just gonna be you run into it and it will move? or will we have to make a mechanism to lower it for us? Any thoughts?
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 07-01-2012, 20:58
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Like I said before, little t-rex arms.
