Go to Post My nephew...loves FIRST. He wants to be an X-Cat but since he lives in Atlanta and that's a heck of a long commute for meetings I told him he probably should strive to be the next best thing: a CircuitRunner. - Koko Ed [more]
Unread 07-01-2012, 16:05
LondonBoy29's Avatar
LondonBoy29 LondonBoy29 is offline
A Man 3000 Miles away from his team
FRC #1884
LondonBoy29 is on a distinguished road
Drive Systems
What drive systems are people thinking about using for this game? It looks like a 6 wheel drive will be best (because of the barrier), but I can see ways to use a mecanum or swerve drive (using the bridge).
Unread 07-01-2012, 16:20
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: Drive Systems
A lot of teams are going to go mecanum because of the existence of protected zone, but defense will be aggressive in preventing them from getting there.
I can see 4 wheel tank being viable due to the fact it makes getting ground clearance for the bump easier (see 330's 2010 bot) as well as working on widebody robots.
As with nearly any game, 6 wheel tank is viable and will be the most commonly used drive, and since the kitbot is 6 wheel drop center, FIRST engineers thought it could play the game.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 07-01-2012, 16:32
Zoughtbaj's Avatar
Zoughtbaj Zoughtbaj is offline
Systems Integration Member
FRC #1983 (Skunkworks Robotics)
Zoughtbaj is on a distinguished road
Re: Drive Systems
I'm curious if anyone is going to try to build a drive train to actually circumvent the barrier. The only things I can think of to do that would be either rather large wheels or a tread drive (after actually seeing the barrier, normal wheels will likely be an "improbability" ). Then again, the rules are strict enough in regard to passing over the balance boards (G25, G28, G29) that I doubt there will be a need to go over the barrier. Our team has been developing a 6-wheel drive system that we are pretty happy with, because of the increased mobility over the 4-wheel. However, 4-wheel drives will have a fine time navigating the field as well, I think.
"The Few. The Proud. The Skunks."
Unread 07-01-2012, 19:25
tlivingd's Avatar
tlivingd tlivingd is offline
FRC #4095
tlivingd will become famous soon enough
Re: Drive Systems
Our team is thinking along the lines of above, but i'm not going to say how much of above
Nate
Mentor Team #4095 Team RoXI
Student Team #13 BioBeast
Unread 07-01-2012, 20:21
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Drive Systems
I've come up with about 5 or 6 different ways to climb over the 4 inch tall barrier. Are the biggest wheels allowed this year 8 inches? I couldn't find anything in the "The Robot" section of the manual. If so, then I instantly have another half dozen solutions.
Unread 07-01-2012, 20:22
Andrew Lawrence
Posts: n/a
Re: Drive Systems
We have a way through them. How? Watch SVR in 11 weeks and find out!
Unread 07-01-2012, 20:23
Re: Drive Systems
If you can't find a rule restricting wheels, then wheels should be considered unrestricted. Have at it.
You could always ask the GDC to be certain, but I can only think of one wheel restriction rule (back in '09).
Unread 07-01-2012, 20:34
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Drive Systems
Our team is also coming up with ways to jump the bump, but I'm actually surprised that people think mecanum will be used by a lot of teams. HDPE floors? Bumps? Bridges? Those will not be nice to your poor Swiss wheels.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 20:37
Andrew Lawrence
Posts: n/a
Re: Drive Systems
Have 2 pneumatic cylinders between the front and middle wheels, pointing down. Then, at the press of a button, the shoot out for a second and come back in, lifting your robot into the air, and giving it room to get over the bump.
Unread 07-01-2012, 20:40
Ninja_Bait's Avatar
AKA: Jake Potter
Re: Drive Systems
Who are you, Speed Racer? Do you also have cutter blades, a bulletproof canopy and a homing pigeon? Oh no, the homing pigeon is like a minibot! Arrrrrrghfuuuuuu!
Unread 07-01-2012, 20:46
pfreivald's Avatar
AKA: Patrick Freivald
Re: Drive Systems
I think octocanum with barrier assist sounds about right for this one...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 20:48
Gdeaver Gdeaver is offline
FRC #1640
Re: Drive Systems
Wouldn't lifting the robot violate the bumper height rule?
Unread 07-01-2012, 20:51
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Drive Systems
I wondering how people are expecting to get the Bridge down from its nuteul position. Any thoughts??
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 07-01-2012, 20:53
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Drive Systems
Little t-rex arms in the front of the robot.
Unread 07-01-2012, 20:54
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Drive Systems
Depends on how high you lift the chassis.
Also, you'd need to be careful of 'articulating' bumpers.
___________________
- Tennyson, Ulysses
