Go to Post The theory is we'd lose a paper list but we haven't lost a student yet. - Peter Matteson [more]
Unread 07-01-2012, 19:56
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
20DP Delrin Gears
So in looking for 20 DP gears, I found these:
http://www.sandeepindustries.com/pla...ded_gears.html
Our team is looking to use them in our drivetrain in order to create a custom gear box, specifically, the 80 tooth one. Would these hold up? Also if not, does anybody know where to get 20dp gears somewhere in the 75 to 85 tooth range?
Thank you so much,
Nathan
Unread 07-01-2012, 20:05
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: 20DP Delrin Gears
Thank you so much,
Nathan
for drivetrain use, I'd suggest pocketed steel or solid AL gears. Plastic gears are too flimsy; they are mainly for lighter loads with less torque.
Unread 07-01-2012, 20:51
nnfuller's Avatar
AKA: Alumni
FRC #2733 (Pigmice)
But where can I find them?
Unread 07-01-2012, 20:59
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
http://www.andymark.com
http://www.sdp-si.com
http://www.wmberg.com
Unread 08-01-2012, 10:00
nnfuller's Avatar
AKA: Alumni
FRC #2733 (Pigmice)
So I have found gears that might work, but they all have 20 degree pressure angles. I am not experienced enough with gears to know whether these would be completely incompatible with the 14.5 pressure angle gears from AndyMark. Any advice?
Unread 08-01-2012, 10:18
Yes, they would be completely incompatible. Gears need the same DP and pressure angle to work together.
