Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Unread 07-01-2012, 18:34
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Lasers
I noticed in the robot rules that Class 1 lasers are permitted. Does anyone know of a relatively inexpensive laser rangefinder with a range of at least a few meters that has a class 1 laser?
Unread 07-01-2012, 19:06
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Lasers
I don't know of such a device.
This article is worth reading. One of its conclusions is that, "in order to be effective, it is clear that a laser pointer has to use a laser above Class 1."
Richard Wallace
since 2003
Unread 07-01-2012, 20:30
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Re: Lasers
As far as I know, this rule has been created to allow use of the Kinect on the robot. The IR beam that the Kinect emits is considered Class 1.
The Kinect can make for a good rangefinder, as can the new ping sensors
Unread 07-01-2012, 20:49
baronep's Avatar
Student President
Re: Lasers
But (correct me if i am wrong) the problems with using the kinect on the robot are...
1 - you would have to use a seperate, usb enabled sensor computer to at least stream the video to the cRIO
and
2 - because of the grid technology used by the kinect, the grids would overlap and corrupt the data
Re: Lasers
Originally Posted by carrillo694 View Post
...the new ping sensors
Do you mean these?
Richard Wallace
since 2003
Unread 07-01-2012, 21:01
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: Lasers
No need for a distance sensor. Use vision to determine the angle of the goal above horizontal. You now know the range from trig.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-01-2012, 21:12
Alex Carrillo
Re: Lasers
Originally Posted by Richard View Post
Do you mean these?
Indeed.
To use the Kinect, we would need another computer on the robot to process the Kinect USB data and send higher-level data to the cRIO via the ethernet network or serial. Also, two robots with Kinects would indeed interfere with each other.
Assuming the distance sensors are for finding the distance to the hoops, then the camera can be used. But what about finding the distance to the walls, or other autonomous robots? Just some hypothetical thoughts.
