Go to Post If I can do it, it's not art. - Ether [more]
Unread 07-01-2012, 20:54
cricket66 cricket66 is offline
AKA: Robin Taylor
FRC #2062 (CORE)
cricket66 can only hope to improve
Re: Drive Systems
What is the bumper height restriction this year. I see nothing in the specs.
Unread 07-01-2012, 21:03
tlivingd's Avatar
tlivingd tlivingd is offline
FRC #4095
tlivingd will become famous soon enough
Re: Drive Systems
R01, blue box
[R01] see the whole rule as trimmed for content......... The Frame Perimeter of a Robot is defined by the outer-most set of exterior verticies on the Robot that are within the Bumper Zone, which is between 2 and 10 in. from the floor. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the Frame Perimeter.
To determine the Frame Perimeter, wrap a piece of string around the Robot at the level described in [R02]. The string describes this polygon.
Note: to permit a simplified definition of the Frame Perimeter and encourage a tight, robust connection between the Bumpers and the Frame Perimeter, minor protrusions such as bolt heads, fastener ends, rivets, etc are excluded from the determination of the Frame Perimeter.
Why this isn't in the bumper section i'll never know.
EDIT: Howdy neighbor! :-)
Nate
Mentor Team #4095 Team RoXI
Student Team #13 BioBeast
Unread 07-01-2012, 21:06
tlivingd's Avatar
FRC #4095
Re: Drive Systems
Originally Posted by Daniel_LaFleur View Post
Depends on how high you lift the chassis.
Also, you'd need to be careful of 'articulating' bumpers.
Please see:
[R30]
Bumpers may not be articulated.
Nate
Unread 07-01-2012, 21:07
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Drive Systems
Originally Posted by tlivingd View Post
Please see:
[R30]
Exactly why I mentioned it
___________________
- Tennyson, Ulysses
Unread 07-01-2012, 21:43
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Drive Systems
May our 14" mechanism expand in the bumper zone outside the robot?
Unread 07-01-2012, 21:50
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Re: Drive Systems
I would assume so. My POV regarding this is that the bumper zone is only a bumper zone when there are bumpers present. That sounds a bit confusing, but what I'm saying is, you have your bumpers set with the openings, then you have an arm(or whatever) at the same level as your bumpers, then yes, its seems like you can expand there(if that's what you're asking)
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
joek is an unknown quantity at this point
Re: Drive Systems
Originally Posted by Ninja_Bait View Post
Our team is also coming up with ways to jump the bump, but I'm actually surprised that people think mecanum will be used by a lot of teams. HDPE floors? Bumps? Bridges? Those will not be nice to your poor Swiss wheels.
their actually one of, if not the strongest wheels out there (an aluminum and steel sandwich). that said, you probably should use hard rubber rollers, as the soft one might get chewed up. also, u will want 10", because the boards are 4" high...
they never said that the part their attached to can't move...
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
pfreivald's Avatar
AKA: Patrick Freivald
Re: Drive Systems
Originally Posted by Gdeaver View Post
Wouldn't lifting the robot violate the bumper height rule?
I don't think so -- any more than driving across a tilted ramp would violate the bumper height rule. The bumper height is clearly relative to the robot, and not to the absolute plane of the court floor, else any ramp action is inherently illegal.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 23:06
Andrew Zeller's Avatar
Andrew Zeller Andrew Zeller is offline
Mechanical Engineering at UA
FRC #1716 (Redbird Robotics)
Andrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura aboutAndrew Zeller has a spectacular aura about
Re: Drive Systems
Originally Posted by Zoughtbaj View Post
I'm curious if anyone is going to try to build a drive train to actually circumvent the barrier. The only things I can think of to do that would be either rather large wheels or a tread drive (after actually seeing the barrier, normal wheels will likely be an "improbability" ). Then again, the rules are strict enough in regard to passing over the balance boards (G25, G28, G29) that I doubt there will be a need to go over the barrier. Our team has been developing a 6-wheel drive system that we are pretty happy with, because of the increased mobility over the 4-wheel. However, 4-wheel drives will have a fine time navigating the field as well, I think.
hmmm.... http://www.youtube.com/watch?v=5MgdG...eature=related
FIRST ROBOTICS TEAM 1716 Redbird Robotics
2012 Wisconsin Regional Judges Award
2012 Wisconsin Regional Quarterfinalists
http://www.frc1716.org/
Unread 07-01-2012, 23:15
AKA: Simon Bohn
Re: Drive Systems
Team 610 in 2010 had ~10" pneumatic wheeled 6WD; the middle one rose and lowered so that they had an easier time with the bump. I'll try to find a video, but most of them are low res taken from far away. Anyone have a picture of it? Still my favorite robot of all time.
Unread 07-01-2012, 23:19
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: Drive Systems
Done.
http://frc-designs.com/html/CAD_2010.html
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 08-01-2012, 01:46
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
Re: Drive Systems
This was posted in a different forum. It's a really cool way to drive the robot, but i'm not completely sure how effective it would be for this years game.
http://youtu.be/uaT7M3Nwj7c
- 2013
Thinking outside the box implies you have limited yourself in the first place.
Robots
