Go to Post I'm sure someone somewhere worked [I]really hard[/I] on this and I congratulate them for the attempt. Unfortunately, its one of those things that should be taken down and recorded in the company journal as a bad idea. - Katie_UPS [more]
Unread 07-01-2012, 21:35
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: Question about returning basketballs
Originally Posted by delsaner View Post
[G31] states that Inbounders may hold a maximum of two balls, and the balls must be returned immediately upon arrival to the corral. Juggling the balls would break that rule.
There are two possibilities: Juggling is an exception to this rule or you may not throw balls to eachother.
Only Inbounders may contact Basketballs; each Inbounder may hold a maximum of two Basketballs. During Teleop, Inbounders must remove Basketballs from the Corral immediately upon arrival. All Basketballs in the Alliance Station must be held by Inbounders once removed from the Corral.
Unread 07-01-2012, 21:36
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
I'm rather glad of this new design. It breaks the large possibility if it were the opposite way of a 469-style 2010 repeat.
Attending: MN Duluth Regional
Unread 07-01-2012, 21:37
pfreivald's Avatar
AKA: Patrick Freivald
Originally Posted by KrazyCarl92 View Post
This would mean that the inbounders MUST put some balls into play regardless of whether or not their alliance can retrieve the balls right away, leaving them possibly where robots from their opposing alliance could get to them first and score them.
Indeed... This means that some rapid scoring and floor ball pickup could result in a serious advantage in-game.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 07-01-2012, 21:39
AKA: Simon Bohn
But you have to work together with your alliance to score in multiple hoops in quick succession to make this viable.
Unread 07-01-2012, 21:51
pfreivald's Avatar
Indeed! Or not, if your opponent doesn't have a designated ball-distributor!
Team 1551
I write books, too!
