Go to Post You cannot change people, you can only change yourself. - KenWittlief [more]
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Unread 07-01-2012, 21:54
sometimestommy's Avatar
sometimestommy sometimestommy is offline
Schrödinger's Assistant
AKA: Thomas Moll
FRC #1939 (Ku-Nig-Its)
sometimestommy is on a distinguished road
Ball Launchers? Ideas?
Hey there. Today we discussed various launchers.
Spring Loaded
Throwing Arm
Pnuematics?
Any ideas? Pro/Cons?
Thanks!
Thomas 1939
Unread 07-01-2012, 21:58
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Ball Launchers? Ideas?
I want to see the animation robot with the plunger to pick up balls and the boots that spin to kick them. Could you do that please. It would be very awesome.
Every day is a new adventure!!!
Unread 07-01-2012, 22:03
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I'm actually thinking of a conveyor belt going from an intake roller all the way up to 2 wheels that spin like pitching machine wheels to launch the ball. 45 degree angle for maximum distance, adjustable speed on the wheels for height.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 07-01-2012, 22:10
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Spring Loaded
Throwing Arm
Pnuematics?
A con is reload time. It takes all of those systems time to reset for the next shot.
I was actually thinking of a similar system to this. There is no reload time on the shooter so shots can be fired quite quickly.
461 Westside Boiler Invasion
45 Technokats
Unread 07-01-2012, 22:13
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Something similar to this, but "tank treads" instead of wheels
Unread 07-01-2012, 22:14
AKA: Thomas Moll
Ive worked out an equation for trajectory that will hit an exact point (middle of hoop) based on a fixed theta (angle of launcher) and a variable velocity (wheel or spinning boot speed)
Its still the FIRST day of this build season so we will have to see
Unread 07-01-2012, 22:18
AKA: Thomas Moll
So the rules dont have a maximum "Muzzle Velocity" hmmmmmmm
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We actually discussed the tank tread idea as well, but one of our mentors brought up a really good point. How many commercial pitching or throwing machines do you see with tank treads? With a foam ball especially, the shortest amount of time that the ball can be in contact with the wheels will not only benefit the condition of the balls (if the belts spin at different speeds at all, the ball spins and it could do some damage to game pieces), but also will help with size, weight, and ease of construction of the mechanism.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 07-01-2012, 22:21
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Check out 1771 on FRC Designs Gripper page (See Link Below). This arm used a suction system to grab the ball and then used a device to launch the ball.
http://frc-designs.com/html/grippers.html
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 07-01-2012, 22:29
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Matt
I wish FRC Designs had some stuff from '06...
Unread 07-01-2012, 22:40
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Matt
Yup, it was a big funnel with an impeller for suction, then 4 pneumatic cylinders that shot it out.
We also used 2 smaller suction cups in 2010 for the soccer balls. Although we got through 1 regional with them, we quickly switched to a roller design before championships. The problem with the soccer balls (and probably these foam basketballs) is that it isn't an even surface, so it was hard for the suction cups to get and keep suction on.
Unread 07-01-2012, 22:41
burnzkid burnzkid is offline
4H JCPenny CCTL Elemental Dragons
AKA: Morgan Burns
FRC #3680 (4H JCPenny CCTL Elemental Dragons)
burnzkid is an unknown quantity at this point
At first we considered a crossbow kind of idea, but now we're moving onto something a little bit more akin to some of the winners from '06.
Unread 07-01-2012, 22:47
AKA: noops
I would steer a bit away from 2006 mechanisms. Those mechanisms had a maximum muzle velocity, and they shot through a hole in the wall, not a hoop with a backboard.
The concept seems fine, but those designs need major mods to make them work with this game.
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
As a 2006 FRC participant (Aim High) who built a robot using the pitching machine launcher design, I have a few comments about it:
First off, calibrating the wheels ended up being a little more annoying than expected. Even though we used encoders to measure and even out the speed between each wheel, we found the release angle was still inconsistent -- the balls needed to be squeezed by the wheels a bit to get the traction needed to accelerate the ball, and the balls would end up flinging a bit to the right or left depending on which wheel made contact with the ball first and how the ball re-expanded.
For Aim High this wasn't a big deal because the target was relatively large, but with baskets this year we need a lot more precision.
Also, the ball originally came out without spin, so the balls flew like a knuckleball, making scoring unpredictable. We changed the speed of one wheel to add spin, but then had to apply a directional bias since the spin did induce lift on one side of the ball (still better than a knuckleball)!
Lastly, we had to run those large softball wheels with CIM motors to get them spinning fast enough, but when they were on all match it quickly drained our battery. In later matches we had to turn off the spinner during collection periods just to save power, then wait for the wheels to spin up to speed again.
I did see effective single-wheel launchers against a static surface that took out a lot of the multi-wheel variable issues we had, and they seemed to work well.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 07-01-2012, 22:50
AKA: Morgan Burns
We're looking into programming the Kinect to help control an aim-able barrel, depending on distance from the hoop and which hoop we're aiming for.
