Go to Post A Guru teaching batteries at Exide: "Do not draw your power from up here, by your terminals. You must reach down deep into your plates and pull the energy from your entire being! You must prove yourself worthy to be FIRST power cells!" - KenWittlief [more]
Unread 07-01-2012, 21:52
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: Strategies for Rebound Rumble
Originally Posted by delsaner View Post
You could pick up the balls are on the opponents side and fire them towards (not necessarily in) your hoops. Instead of blocking shots, starve them of balls so there are no shots TO block. The benefits of this are that you can play defensive with an offensively designed robot.
So, one possible strategy would be to play 2F-1B (2 forward, 1 back). The job of the F players is to scoop up balls and put them in the goals. These would be the primary point scorers. B's primary responsibility is to play defense by preventing ball starvation of the F's. B's secondary responsibility would be to avoid committing penalties. Given the many ways to commit fouls when on the defensive side of the field, this may be fairly difficult to do. Sort of like walking in a minefield.
A B robot could be made exactly like those from the 2010 game and be pretty effective. Of course, the ability to score from the defensive side of the field would be even better. But, even shooting and missing gets the B's job done.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-01-2012, 21:55
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Todd F.
A common and fairly effective strategy in Breakaway was to have scorers and feeders. I expect to see something similar this year, and probably every year with a goal-zone set up like this.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2012, 21:58
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
zone defense or robot on robot defense?
---> having zone defense will probably be the best strategy since it allows two of your robots to continue scoring. and the robot that plays defense should be able to shoot balls across the field- there might be a chance that the robot makes the shot but it gives its alliance more balls to work with without going back and forth across the field.
College Student | "It won't fail because of me."
Unread 07-01-2012, 21:59
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
- Inbounders can bounce pass balls to the far side of the field (see field tour videos on youtube)
Does anyone have a video of the balls bouncing over the bridge?
Unread 07-01-2012, 22:08
AKA: Om Mahida
this?: http://www.youtube.com/watch?v=IaFiC...6&feature=plcp
all the videos about the field are on youtube.com/FRCTeamsGlobal
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
You wouldn't have to bounce it over the bridge. If you enter it into the field at a slight angle, you would only have to make it over the 6 inch barrier.
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
delsaner's Avatar
delsaner delsaner is offline
With Upmost Efficiency
AKA: Eric DelSanto
FRC #1676 (Pascack Pioneers)
delsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant futuredelsaner has a brilliant future
Very true, and completely understandable. I may have initially underestimated the size of the key, but there appear to be a few safe spots for opposing robots to starve balls. For the B robot, as long as the balls get to the offensive zone, B is doing his job. As stated before, shooting into the hoop would be a 2-in-1 deal.
"The creations of the hand are confined by reality. The creations of the mind know no such limits."
~MtG - Mind Unbound
Eric DelSanto
Game Announcer
H.E.R.E. Representative
Stevens Institute of Technology - Class of 2016 - BE/ME Mechanical Engineering
Concentration: Robotics, Mechatronics
[2008-2014]: FRC 1676 - The Pascack Pi-oneers
Unread 07-01-2012, 22:09
donnie99 donnie99 is offline
AKA: Steven
FRC #0237 (Black Magic)
donnie99 will become famous soon enough
A defensive bot will be effective this year no matter if another bot is taller. If a bot is in the key, I don't know how many teams would confidently put a shooting mechanism on an arm. This means that if the ball has to be lower than 60 inches, it will not matter, and of they try to put it into the basket, a defensive bot should be able to push the opponent away.
For a general scoring strategy, I was thinking of using a similar strategy to ours last year, using an encoder to put our shooter into a position so if the strength is set to a certain limit, it would hit the same spot and the have the same outcome each time. Doing this right at the hoops, will almost always give the desired results.
Unread 07-01-2012, 22:14
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
A reliable shooter in the key is going to be the clutch. If you could put a retriever in the lane to get balls and launch them into some sort of hopper on the shooterbot you could stay in the "no-touch" zone most of the match.
Unread 07-01-2012, 22:27
Andrew Lawrence
Posts: n/a
Something I see is at least one main shooter robot that can accurately fire into the top goal by sitting in the key area, one robot feeding it, and another either defending or staring the other team.
Unread 07-01-2012, 22:43
Mewaffleo(CRaz)'s Avatar
Mewaffleo(CRaz) Mewaffleo(CRaz) is offline
Mewaffleo
AKA: CamronR
FRC #0027 (Team RUSH)
Team Role: Student
Mewaffleo(CRaz) is an unknown quantity at this point
In the spirit of FIRST, I see a great strategy in cooperating with the opposing alliance to balance on the middle bridge. This "coopertition" not only gives you points to qualify, but is also a major component of Gracious Professionalism.
Besides the "coopertition" strategy, alliances going for their own bridges is a major point-scorer: 10 points for 1 robot balancing on the bridge; 20 points for 2 robots balancing on the bridge; and 40 points for 3 robots balancing on the bridge during elimination matches only. If alliances get any robots on their bridge, it will be a major advantage.
Another strategy for "Rebound Rumble" is scoring in hybrid (autonomous). If an alliance scores all of the balls they receive in hybrid (6 balls), a maximum of 36 points can be racked up. This puts said alliance in a winning position that would be very hard to catch up to.
Saying all of this, I believe the best strategy would be to score as many high pointers during hybrid, and then during the last 30 seconds of the match have two robots of the same alliance balance on their bridge while the other robot balances with an opposing team's robot on the "coopertition" bridge. Excluding teleoperated ball scoring, that is a total of 56 points!
I hope team benefit from these strategies.
-Camron Razdar (FIRST Team 27, Team RUSH)
stevethetinker stevethetinker is offline
FRC #1288 (RAVEN)
stevethetinker is an unknown quantity at this point
Message 13 provides a link to the episodes of the field tour, but it starts at episode 2. I've looked for episode 1 with no luck (too much search noise on utube). Is the first one worth watching? (the others were.) Where is the first one?
Steve K of 1288
Unread 07-01-2012, 22:47
Flimsor's Avatar
Flimsor Flimsor is offline
The Mad Cadder
FRC #1983 (Skunkworks Robotics)
Flimsor will become famous soon enough
I was thinking that if you had a robot that could score in the lower or middle hoops 90% to 100% of the time it could stay in position right up against the hoop, then we could have another robot picking up balls scored from the feeder and shooting them right at the collection system. If they are aimed well and they can be moved before there are 3 in possession of a robot, then we could really rack up a lot of points.
mrducky mrducky is offline
AKA: Mark Duckworth
FRC #0811
mrducky is an unknown quantity at this point
Steve K of 1288
I saw a note there that said they decided not to publish the first episode, so it starts with episode 2.
Unread 07-01-2012, 22:48
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Does anyone know what the first was supposed to be about, and why they decided to suddenly not release it? In the series, they say it has 6 parts, while now it only has 5.
