Go to Post Scout so that you're not in doubt! - Mark Pettit [more]
Unread 07-01-2012, 22:56
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Windriver Template Error
I've installed Windriver and Labview on a new computer this year, and applied the updates per instructions.
When I go to create a new example from template, it gives me an error, saying the build defaults have not been specified. Does anyone know a solution to this problem? Believe me when I say I do not work with an IDE like WindRiver all that often.
Attending: MN Duluth Regional
Unread 08-01-2012, 00:09
WPI Freshman
AKA: Alex
Re: Windriver Template Error
To those that have similar issues, I have solved the problem. It's a matter of going to Windows->Preferences->WindRiver->Build->Build properties, and change the drop down bar to VxWorks downloadable Kernel project
Unread 08-01-2012, 00:22
WPI Freshman
AKA: Alex
And... Now there's an issue where I can create a template project, but I get a build error saying,
"building SimpleTemplate/Debug/SimpleTemplate.out
nmppc: 'C:/WindRiver/vxworks-6.3/target/lib/WPILib.a': No such file
ccppc: C:/WindRiver/vxworks-6.3/target/lib/WPILib.a: No such file or directory
C:\WindRiver\vxworks-6.3\host\x86-win32\bin\make.exe: *** [SimpleTemplate/Debug/SimpleTemplate.out] Error 1
Build Failed in Project 'SimpleTemplate' (Process Exit Value was 2): 2012-01-07 23:22:06 (Elapsed Time: 00:01)"
Anyone else have similar issues?
Unread 08-01-2012, 00:41
pspeer's Avatar
pspeer pspeer is offline
Programming / Electronics
FRC #1730 (TeamDriven)
pspeer is an unknown quantity at this point
We have found a solution to this problem -> Please check out thread "Cannot Compile SimpleRobot Example - Missing WPILib.a"
