Go to Post Less playing to the camera, more talking about cool FIRST stuff please. - Cuog [more]
  #31   Spotlight this post!
Unread 07-01-2012, 22:53
mrducky mrducky is offline
AKA: Mark Duckworth
FRC #0811
mrducky is an unknown quantity at this point
Re: Strategies for Rebound Rumble
Originally Posted by Hallry View Post
Does anyone know what the first was supposed to be about, and why they decided to suddenly not release it? In the series, they say it has 6 parts, while now it only has 5.
Just go to episode 2 and read the note.
There is no Episode 1. While we love this whole series, we decided not to publish Episode 1 because the animated character was exasperating and seemed like a merchandising opportunity.
  #32   Spotlight this post!
Unread 07-01-2012, 23:05
MathMaven MathMaven is offline
AKA: Elisha Sword
FRC #3175 (Knight Vision)
MathMaven is on a distinguished road
Originally Posted by Silver218 View Post
For any defensive bots, what would be your teams strategy? We have talked about a defensive bot to possibly block shots from opposing teams
Based on what I've seen from the rules, I think a defensive strategy is not a good idea:
  • G14: "Strategies that use Basketballs to either aid or inhibit balancing of any Bridge are not allowed." --There goes one defensive strategy.
  • G20: "Robots in contact with the carpet on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall." --Your Alliance Station is where your opponents score this year; a 60-inch tall robot leaves the second and third rows open for scoring. Clearly, blocking is being discouraged.
  • G23: "Robots on the same Alliance may not work together to blockade the Court in an attempt to stop the flow of the Match. This rule has no effect on individual Robot-to-Robot defense." G24: "Intentionally falling down or tipping over to block the Court is not allowed." G25: "Robots may not contact or otherwise interfere with the opposing Alliance Bridge. . . . If the act of Balancing is interfered with, also a Red Card and the Bridge will be counted as Balanced." --More strategies for defense downplayed.
  • G28: "Robots may not touch an opponent Robot in contact with its Key, Alley, or Bridge." --According to the Blue Box, "This rule applied at all times, no matter who initiates the contact, see [G44]." In other words, you can take advantage of an annoying robot in your Key, Alley, or Bridge (just don't violate [G45]), so it's best to stay away from those areas.
—Elisha Sword
2010–13: FRC Team 3175 (Knight Vision), student, lead programmer
2012–13: FRC Team 3175 (Knight Vision), lead website designer
2014: FRC Team 3175 (Knight Vision), programming mentor
“Who has not been amazed to learn that the function y = e^x, like a phoenix rising from its own ashes, is its own derivative?”
—Francois le Lionnais
  #33   Spotlight this post!
Unread 07-01-2012, 23:06
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Extra balls not placed on robots will be put on the co-op bridge. An autonomous program could suck those balls up after firing the two balls already on. This will be the equivalent of the double hang this year for autonomous.
Two balls will be placed on the alliance bridges. A team with a "tipper" could gain a speed advantage by placing one ball from that robot on the co-op bridge, grabbing the balls from the alliance bridge, and then another robot (or the same, but only after firing the one ball) could take the center ball.
I'm meandering a bit, but a device to tip the balances will be useful on any team's robot and should be incredibly easy to implement.
  #34   Spotlight this post!
Unread 07-01-2012, 23:13
om23 om23 is offline
AKA: Om Mahida
om23 is a jewel in the roughom23 is a jewel in the roughom23 is a jewel in the rough
so is their a 84" height limit of the robot on its scoring side? And where does it say that a robot can't touch the basketball hoops while scoring?
College Student | "It won't fail because of me."
  #35   Spotlight this post!
Unread 07-01-2012, 23:18
donnie99 donnie99 is offline
AKA: Steven
FRC #0237 (Black Magic)
donnie99 will become famous soon enough
It doesn't specifically say you can't touch the hoops, but if you damage them, it will be a penalty under the safety rules, and yes, the most is 84" on the scoring half.
Also, what would be good for scoring is to not be in the key unless you have an extremely reliable shooter. A bot with 6 or 8 wheel tank drive, or even 4 wheel drive will be hard to move from the side if it has a low center of gravity, and will not move and make it easy to score quick baskets close to the hoops.
  #36   Spotlight this post!
Unread 07-01-2012, 23:19
AKA: Elisha Sword
Actually, there's a universal 84' limit, and a 60' limit if you're on your opponents' side of the Court. Also, you must begin at under 60'.
—Elisha Sword
  #37   Spotlight this post!
Unread 07-01-2012, 23:20
AKA: Om Mahida
someone on my team today said that we should calculate the Center of Mass for each robot and calculate the I value so we will be able to balance the bots in the end game efficiently!
  #38   Spotlight this post!
Unread 07-01-2012, 23:21
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
It was shot down in our meeting, so here is my idea:
Make a robot with a ramp allowing another robot to drive on top of you, and you then solve the problem of how to get 3 robots on the bridge. Also, you can use it with your opponent's robot so you and your opponent can easily balance on the Coop bridge together as one entity rather than two.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
  #39   Spotlight this post!
Unread 07-01-2012, 23:22
Andrew Lawrence
Posts: n/a
I see that as the "Work 100% of the time defensive robot that does not ever play offense."
In other words, for a defensive robot would just dominate with that!
  #40   Spotlight this post!
Unread 07-01-2012, 23:25
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
The bottom half of the robot could still pass around balls to your team mates on the other side of the field.
But since the rest of the team wanted a very offensive robot, I stood down and will love to see any other team take that on.
  #41   Spotlight this post!
Unread 07-01-2012, 23:26
AKA: Elisha Sword
That's genius!
Of course, you'd still need to make the robot able to score baskets, but still!
—Elisha Sword
  #42   Spotlight this post!
Unread 07-01-2012, 23:29
Tetraman's Avatar
FIRST on my mind
AKA: Evan Raitt
I mean, I imagine one robot right under the Inbounder, and with a high powered burst of speed you rocket the ball straight from the Inbounder to the other side of the field (and up your bridge too, if you set it right). Imagine how easy that would make gathering balls to your team mates.
  #43   Spotlight this post!
Unread 07-01-2012, 23:30
Registered ConfUser
AKA: Mark McGivern
Originally Posted by MathMaven View Post
That's genius!
The robot, provided it is a kitbot/KoS/similar pattern, would not rest on the middle of the robot. Make a hole in whatever surface you would use in the center, where wheels would not touch, and throw balls through there.
  #44   Spotlight this post!
Unread 07-01-2012, 23:32
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
sounds like this http://www.wildstang.org/main/video.php?year=2001
461 Westside Boiler Invasion
45 Technokats
  #45   Spotlight this post!
Unread 07-01-2012, 23:47
Registered ConfUser
AKA: Mark McGivern
Originally Posted by Tubatroopa View Post
The challenge in making a rampbot will definitely be overcoming the 14-inch protrusion limit, a constraint this robot didn't have.
