Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 07-01-2012, 16:03
That Canadian That Canadian is offline
FRC #0346 (RoboHawks)
That Canadian is an unknown quantity at this point
Java Kinect class question (getPosition())
In the new Kinect class there is a method getPosition that returns a Kinect.Point4 variable. Within the varaible there is an x, y, z, and w float value. Now I know what the x, y, and z variables are representing but what is the w value for?
Unread 07-01-2012, 16:39
Re: Java Kinect class question (getPosition())
For more details on the four member vertex, take a look in the Microsoft documentation for the Kinect. The short answer is that it is normally not used. It is present because it is useful when performing spatial transforms. The exception is that w contains useful info when describing the floor plane as identified by the Kinect.
Greg Mckaskle
Unread 07-01-2012, 23:27
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Is the Kinect's w coordinate anything like the w coordinate in homogeneous coordinate spaces?
Although on http://blogs.msdn.com/b/eternalcodin...ndows-sdk.aspx it says that it's the "quality level." So would it instead be the certainty with which it can determine the coordinates?
Unread 08-01-2012, 08:53
The Kinect SDK that was installed with the Kinect drivers has a section on structures and here is an excerpt.
vector4_u32
Four unsigned 32-bit integers.
x
X coordinate.
y
Y coordinate.
z
Z coordinate.
w
W coordinate. For the floor plane, the W value is the distance from the plane to the origin. For all other vectors, this value is 1.0.
Greg McKaskle
