Go to Post It will be really cool if it works, sad if if doesn't. We got our fingers crossed! - falconmaster [more]
Unread 07-01-2012, 22:54
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
2012 Windriver Install problem
We have installed disk one of windriver 3.0 but when the second disk with 3.3 is installed, when you open 3.3 you get a conflict with 3.0... Are supposed to only used disk two (says install for windows 7 and xp 64 bit...)?
Unread 07-01-2012, 23:38
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: 2012 Windriver Install problem
What kind of error is it? Are you using the same initial workspace?
Attending: MN Duluth Regional
Unread 07-01-2012, 23:40
Chexposito's Avatar
AKA: Expo
FRC #1730
nvm, found error
Unread 08-01-2012, 02:35
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Originally Posted by Chexposito View Post
nvm, found error
Please share the error and what you did to avoid it for the benefit of others who may search the forums for a solution.
Joe
Unread 08-01-2012, 13:43
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
In the instructions it said to be sure not to run WindRiver 3.0 after you install disk one. If you did, you would get an error when you tried to run 3.3. You have to kill the WindRiver Registry in your taskbar. Also look for the WindRiver Registry in Task Manager and kill it. Then run 3.3. That should work.
Also, make sure you install all of the National Instruments Software or you will not see the FRC Examples.
If you need any more help, just ask me. I had the same issues and fixed it this morning.
-Eagle Engineering 1138
Unread 10-01-2012, 09:35
Ross3098's Avatar
Ross3098 Ross3098 is offline
Programmer
AKA: Colin Ross
FRC #3098 (The Captains)
Ross3098 will become famous soon enoughRoss3098 will become famous soon enough
This would mean that the WPILib would also be missing before installing the NI Software correct? Im currently wondering why I had no projects/WPILib files.
2012 FRC Championship: 4th pick, Quarterfinalist: Thanks 1507, 51!
2012 Michigan State Championship: 4th Seed, 3rd Alliance Captain, Semifinalist: Thanks 33 and 2137!
2012 Northville District: 3rd Pick, Quarterfinalist. Thanks 302, 4405!
2012 Waterford District: 2nd Pick, Finalist. Thanks 573, 3601!
2011 Waterford District: 8th seed, 1st pick, Semi Finalist. Thanks to 573 and 3770
2011 Ann Arbor District: 2nd seed, Finalist. Thanks to 548 and 247.
2011 Michigan State Championship: Semi Finalist. Thanks to 548 (Again) and 74.
2011 FIRST World Championship: 8th seed, Quarterfinalist. Thanks to 74(Again) and 846.
Unread 10-01-2012, 14:50
This is inaccurate. The NI software that needs to be installed is the Tools / Utilities base software. This installs the drivers needed by the cRIO Imaging Tool.
You need to install the C++ Workbench update to get the examples and WPILib.
Note that the installer first posted for kick-off was missing the WPILib.a file. This was corrected Sunday morning and should now be available and working correctly.
-Joe
