Go to Post Blame it on the programmer. - colt527 [more]
Unread 04-01-2012, 17:17
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Suggestion for driver station computer
Does anyone have any insight into a good non-classmate driver station laptop. We would like the screen to be big enough to see a camera on (~15"), NOT HOT (we had a driver station last year that overheated a lot and was pretty glitchy as a result) and not too expensive (<$500, preferably less than 400)
Thanks
Patrick
Unread 04-01-2012, 17:44
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Suggestion for driver station computer
Used Lenovo ThinkPad T61, T61p, X61 or X61s. They're all quite durable, have matte screens, and (when equipped with Core 2 Duo processors) will easily outperform the Atom in the stock Classmate. And black matches everything.
The T61 series is in your size range, and can be had for $250 or less (I can send you a couple links if interested). The X61 series laptops aren't that big, but can come with a high-resolution screen with a 4:3 aspect ratio (useful for displaying the driver station readout below the camera output).
Make sure the battery is good (or spend a little and buy a new one). You can run TPFanControl to force the fan to keep it very cool, if that's what you want. (Fan noise won't be a problem in an FRC driver station....)
Use it before the end of the build season, so that you know everything works. (If you can't do this, it might be best to get a new laptop instead to minimize possible failures.)
Unread 04-01-2012, 18:20
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
In the past, $400 was the maximum for any purchased component. I think that the Driver Station computer would be in that category. The speed of the laptop may be an issue this year. The Kinect will probably connect to the Driver Station laptop. That may increase the computation requirements.
Unread 04-01-2012, 18:50
The operator console (including the computer running the driver station software) was exempt from cost accounting per 2011's <R20E>.
Unread 04-01-2012, 20:14
AKA: Randy
Sorry, next time I'll read rather than use my faulty memory.
Unread 04-01-2012, 22:14
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
At this point, I'd recommend waiting for kickoff in case there are some new rules about drivers station hardware for 2012.
Unread 07-01-2012, 23:42
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
Looks like there aren't any changes, as per <R13G>.
Unread 10-01-2012, 04:56
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
So, now that we've gotten through kickoff, let's bump the topic.
My team is also considering a new driver station, especially in light of the added load of the Kinect.
What are other teams using and having good luck with? What suggestions are out there?
Cheap, rugged, compact would be pluses...
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 10-01-2012, 08:10
If you intend to use the Kinect on it, be sure to consider the HW requirements from the Kinect read me file.
Hardware Requirements
32 bit (x86) or 64 bit (x64) processor
Dual-core 2.66-GHz or faster processor
Dedicated USB 2.0 bus
2 GB RAM
Windows 7-compatible graphics card that supports DirectX 9.0c
A retail Kinect for Xbox 360® sensor, which includes special USB/power cabling
I've seen it run OK on that class of computer, but the i3, i5, and i7 computers had far more CPU left over.
Greg McKaskle
Unread 10-01-2012, 08:18
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
What version of Windows 7 is necessary?
Unread 15-01-2012, 09:15
Brian Holford Brian Holford is offline
GrimsleyEE
FRC #3215 (Prion)
Brian Holford is an unknown quantity at this point
Is there a Field Control System Setting Checklist for the driver station?
The getting started guide only has instructions for running the setup.exe file on the classmates, not configuring a user ID for a new computer.
Last year our team attempted to use Lenova Laptops instead of the classmate.
The first obvious error that we had was not formatting the "driver" user account name properly (case sensitive).
Then we had several problems with the internet connectivity not being recognized by the field. I'm pretty sure this was from not disabling the wireless adapter but the computer was not recognizing the wired network properly and our team unfortunately delayed a few matches while we were trying to resolve this.
In the heat of competition we opted to go back to using the classmate, but we certainly would like the option of more computing power on the field.
Last edited by Brian Holford : 15-01-2012 at 09:17. Reason: IIRC Development Season is done Wireless, FCS used Wired Network
Unread 15-01-2012, 10:43
The field no longer pays attention to the login name. Driver, driver, or chauffeur, it doesn't matter. I also have not seen issues with the wifi being left on, but that may depend on its IP address.
As to the original question, I can't say that I know of a checklist.
Greg McKaskle
