Go to Post Wow, my dad's sadistic nature is rubbing off on me. - Lil' Lavery [more]
Unread 07-01-2012, 16:52
ValoryxD ValoryxD is offline
Tighten Your Bolts!
AKA: Web Rep.
no team (Fallout)
Team Role: Webmaster
ValoryxD is an unknown quantity at this point
Kinect options
Can you have multiple kinects? i heard you can attach it to the robot itself, but they never said you couldnt have more than one. Clarification?
Unread 07-01-2012, 17:39
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Re: Kinect options
Like, multiple Kinects on the robot? Like more than one?
This is like having 39 wheel drive.
One Kinect is more than enough for usefulness and giving a headache to programming. I suuuuppooooooosse you could have one facing forward and one facing back, or three pointing in all directions so you can have a true 360 degree view of the field. But no. That's just more complicated than it needs to be. Or that can be done in 6 weeks. People are still trying to figure out how to connect one Kinect to the cRIO. I don't think there needs to be a rule about it.
Is there anything specific you had in mind or something???
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 07-01-2012, 20:03
alfredtwo alfredtwo is offline
alfredtwo will become famous soon enough
Re: Kinect options
I think the limit is one Kinect during the autonomous time. I don't know that there is a rule against multiple Kinects on the robot though. You should know that the Kinect takes a lot of the USB bandwidth so if you want to use 2 you will want 2 USB controllers. The Kinect SDK does support at least 2 (not sure about more) on a computer. In fact the sample software that comes with the Kinect for Windows SDK has an option to select which Kinect to use.
Alfred Thompson
Academic Developer Evangelist - Microsoft
Proud co-founder of Team 811
Unread 07-01-2012, 20:34
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Kinect options
I have a different Kinect question, and this post seems like the right spot to post it.
Can you have a Kinect on your driver's station?
Can you have a Kienct on your driver's station as well as your robot?
Unread 07-01-2012, 20:36
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Re: Kinect options
Good luck interfacing just one on board the robot.
Unread 07-01-2012, 23:35
279 EMPIE's Avatar
279 EMPIE 279 EMPIE is offline
Head Progammer
AKA: Matthew Empie
FRC #0279 (Tech Fusion)
279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice279 EMPIE is just really nice
Send a message via AIM to 279 EMPIE
Re: Kinect options
Has one figured out how to use the kinect to scan for objects like the balls or for the targets on the hoops?
2011- Programmer, Electrical, and Web
Cleveland Regional
2012- Head Programmer, Web, Driver
Pittsburg Regional, Saint Louis International
2013- Head Programmer
Cinnicinatti Regional, Taraho Regional
Unread 07-01-2012, 23:40
279 EMPIE's Avatar
Head Progammer
AKA: Matthew Empie
Re: Kinect options
Looking at the examples in netbeans for the kinect, it doesnt seem very hard to program it to move the robot when you make certain movements.
Cleveland Regional
Unread 07-01-2012, 23:45
Migriemsl Migriemsl is offline
AKA: Marcene Grimsley
FRC #3743 (Eaglebots)
Migriemsl is an unknown quantity at this point
Re: Kinect options
I know for a fact you can have a kinect on the actual robot, but there is no rule about the driver's station. That is a gray area, there is no mention in the rules so it is a possibility. The overall effectiveness of the distance between the hoops and the driver station is a concern for me. I'm uncertain of the range but if the hoops are indeed your target then range research is an idea, but if you have other plans then I again go back to the gray area regard. If this isn't helpful I apologize.
Unread 08-01-2012, 01:07
Ernst's Avatar
Ernst
AKA: Ernst
Re: Kinect options
I found it.
[R84]
Other than the system provided by the Arena, no other form of wireless communications shall be used to
communicate to, from or within the Operator Console.
Examples of prohibited wireless systems include, but are not limited to, active wireless
network cards and Bluetooth devices. For the case of FRC, a motion sensing input device
(e.g. Microsoft Kinect) is not considered wireless communication and is allowed.
(emphasis mine)
This states that the Kinect is allowed to communicate with the Operator Console (The Driver's station).
I'm honestly not entirely sure what my intent was for placing a Kinect in the Driver's station.
