Re: Wheel Size?
I think we should use a custom sized tank drive system that is the exact maximum dimensions allowed. That way, if the robot gets flipped over it can still drive, and we can get over the bump.
Re: Wheel Size?
You should totally make adaptive-geometry wheels to get over the bump in the middle.
Re: Wheel Size?
They might be used in future lunar rovers, so they should be good enough for FIRST. Last edited by Ernst : 08-01-2012 at 13:25. |
Re: Wheel Size?
Along the lines of cool and not really helpful.
I have not been able to come up with a engineering reason as to why tri-star wheel is better than a regular wheel of the same over all size. But like the design all the same. For those that aren't sure what is going on here it is the same setup as a planetary gear system with the ground acting as the ring gear. |
Re: Wheel Size?
Re: Wheel Size?
#7
Re: Wheel Size?
Slightly irrelevant, but I remember a team that had a large gear dropped on their robot during shipping. That would suck.
#8
Re: Wheel Size?
