Go to Post There are few times I sleep so soundly as I do after an FRC build season and regional. - JamesCH95 [more]
Unread 08-01-2012, 01:03
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: The Barrier Thread
To everyone who thinks you can cross the bump unaided (that video shows what lifting the robot before the wheels hit can do) with 6" wheel, I'm fairly sure that is wrong. The center of your wheel is 3" off the ground and as such you would ram flat into the metal. MY guess is that you'd break the wheels or send your robot hurtling head over heels before it would go over the bump. Even a 8" wheel would be sketchy, because it is level with the top of the metal. To be certain you would need 10" wheels.
Unread 08-01-2012, 01:04
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
or you can have pneumatic wheels
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
Unread 08-01-2012, 01:26
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Originally Posted by Grim Tuesday View Post
Breakaway was a much higher drop, though.
EDIT: How would we do the math for this?
I believe what you're looking for is shear stress analysis.
If the side-profile of your robot is trapezoidal-esque - that is, you have powered wheels elevated above the ground - you'd be able to do so with 6" wheels.
I don't personally believe that people will break their wheels by anything, including driving into the rail (which is steel, as can be confirmed by the CAD) - if they do, it'll be because the wheels will have already experienced heavy damage - but I do expect to see wheels damaged by collisions and impacts. Plactions will crack very easily if you abuse them enough.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 08-01-2012, 01:30
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
My question on math was how we would calculate if a wheel can climb a surface, my bad.
Unread 08-01-2012, 01:31
slijin's Avatar
Pockets
AKA: Samuel Lijin
Then you'd be comparing the net upwards force (acceleration and friction) to gravity.
Unread 08-01-2012, 01:39
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Alex,
If you actually do the math and check your geometry, you will come to the conclusion that a 8wd 6" wheel will definitely clear the 4" "Bump". Also there are a lot of ways with 4"-6" wheels you can clear it. 10" wheels would be a bit overkill.
-RC
R.C.
MadTown Robotics Team 1323
Unread 08-01-2012, 02:19
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I was thinking about this too, the 8 inchers from AndyMark are lookin' especially nice right about now...
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 08-01-2012, 03:16
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Originally Posted by R.C. View Post
Alex,
-RC
Yeah, our feeling is that just throwing more wheels at the problem would be more effective than massive wheels.
Unread 08-01-2012, 06:53
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
FRC gamers are so used to nice flat surfaces (for the most part) we hardly ever think of a standard vehicular feature ---- suspensions. I'm looking forward to see what the 6WD fans do for this year.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 08-01-2012, 13:40
DonRotolo's Avatar
Back to humble
FRC #0832
To everyone who thinks you can cross the bump unaided <> with 6" wheel, I'm fairly sure that is wrong.
Sorry, but I have to disagree. I can even do it with 4" wheels.
As a trivial example, imagine a wooden 'ramp' at the front end of the robot (inside the bumper perimeter), starting at 5" and ending at 2". Hitting the barrier at speed will launch the bot over.
As for high-centering, if you use Gates Belt instead of chain, it can act as a tank tread for between the wheels.
Unread 08-01-2012, 13:47
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Key word in the post you quoted was "unaided". Take away the wedge and try again.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-01-2012, 13:48
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
I bet our 2010 robot could make it over with no problems!
http://www.chiefdelphi.com/media/photos/35272Some nice 10in pneumatic tires!
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 08-01-2012, 13:49
Andrew Lawrence
Posts: n/a
We're planning on using the slants in front of our robot along with the 8" pneumatics from Andymark. Deflate the wheels a tiny bit, and they become instant shock absorbers.
Unread 08-01-2012, 15:16
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
come on we have not thought of everything yet just wait in the next couple days we will have something.
No one was dragging you down for not considering the entirety of a design; they were just pointing out the possible flaws before you found them later on...
Unread 08-01-2012, 15:20
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
I think he was being slightly sarcastic.
Every day is a new adventure!!!
