Go to Post FIRST is not a destination, its not the reward, its the slingshot that will launch you from where you are, to where you can be. - KenWittlief [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 08-01-2012, 04:57
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
Re: CAN Issues
Originally Posted by Mr.D View Post
I'm having a setup issue with our Black Jaguars. I am unable to assign a new ID and when I try to update the firmware I get an "Unable to contact the boot loader!" message.
Mode tab: I am able to move the slider to adjust the settings at the bottom of the BDC-COMM screen when connected.
System tab: Board information is: none,none; Hardware Version: 0; Firmware Version: 0; New Board ID: 1
Ideas??
I was having the same problem, it turned out that I had switched the TX and RX pins on the custom adapter cable. Also be sure you've connected GND to GND on the adapter cable. The yellow solid light can be acquired by connecting the V+ and CAN_L or CAN_H to the DB9 adapter. Hope this helps
Eat, Sleep, Build Robots
