Go to Post There is no such thing as "un-GP." - Tetraman [more]
Unread 08-01-2012, 01:15
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Pros and Cons of Pneumatic Wheels?
I apologize in advance if a thread has already covered this, but there are a ton of new threads out there, and a search did not bring up any results.
My basic question is:
What are all the problems and benefits of using Pneumatic Wheels?
This is meant for all aspects of the game. Driving, maneuvering, driving over the ridge in the middle (esp. that), etc.
Thank you!
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 08-01-2012, 08:44
Brian Ha's Avatar
Brian Ha Brian Ha is offline
Teh Ha Kid
FRC #0302 (Team 302)
Team Role: Driver
Brian Ha has a spectacular aura aboutBrian Ha has a spectacular aura aboutBrian Ha has a spectacular aura about
Re: Pros and Cons of Pneumatic Wheels?
While our team did not use them, we had the pleasure of practicing against 469 who used these wheels. They were impossible to push, even when we had grippy wheels and loe gear going. That said, our head mentor mentioned the other day that those kinds of wheels were investigated by "andymark" (i put quotations because im not sure who it was buy im pretty sure andymark did it) and they said that if u deaired them just a little then tjey would get more traction than orange grippy wheels. Also I might aswell pass on this information, our team said that if u do use those wheels slighty deflated, they will work beautifully for the bump.
Anyways sorry for the block of text.
Starcraft 2 Hit me up Cheese 972, or join the FRC chat room ingame
Unread 08-01-2012, 10:56
ThaineP
Posts: n/a
You can get a lot more traction and speed with them, but if you aren't using a Swerve drive, it'll be hard to turn. There are also no pneumatic wheels with 'special' characteristics, e.g. mecanum, omni. My team is using Mecanums this year, hoping for better mobility.
Unread 08-01-2012, 11:09
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Do you know of anyone that's ever tried a combination of pneumatics and some other wheel such as an omni? Do you think that that would work at all?
Unread 08-01-2012, 11:16
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
Off the top of my head:
Pros:
Generally High traction (More pushing power if you've got enough torque)
Compressible (almost a built-in suspension)
Cons:
Generally High Traction (turning is harder, would have more trouble getting traction-limited)
Compressible (could mitigate a center wheel drop)
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 08-01-2012, 11:21
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
http://www.chiefdelphi.com/media/photos/35118
Seemed to work really well for these guys
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 08-01-2012, 11:24
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Cons:
Not if you vary pressure in your wheels. If the center wheel is stiff but the outside two are at slightly lower pressure you could effectively increase the driving radius of the one wheel
Unread 08-01-2012, 11:34
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I seem to recall that 330 has also built 6 wheel drive robots with the center wheels pneumatic, and the end wheels solid. They could adjust air pressure to vary how easily the robot turns, as it also changes the "drop" of the center wheel relative to the end wheels.
(just look at the wheels on this picture)
Unread 08-01-2012, 12:12
ThaineP
Posts: n/a
You could try a 6wd with straight omnis on the front and back and pneumatics in the center, that would be pretty fast with a turn center in the middle of the bot.
Unread 08-01-2012, 12:14
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
And if there were two pneumatics in the front? How would the turning be?
Thanks,
-duke
Unread 08-01-2012, 21:45
Alex.q Alex.q is offline
FRC #2220 (Blue Twilight)
Alex.q is on a distinguished road
Would pneumatic wheels work in a 6wd setup if we dropped the center? I saw someone else who had trouble turning with a off-season chassis, but don't remember how the wheels were configured. There was also talk that the tires could compress and negate the center drop, so could we just drop the wheels slightly more?
If 6 pneumatics wheels wont turn well, what about a 6wd with an 1/8" dropped 8in plaction in the middle?
Thanks,
Alex
Unread 09-01-2012, 02:27
BASE's Avatar
BASE BASE is offline
=ARRAYFORMULA() is a thing?
AKA: Rishi Jotsinghani
FRC #3683 (Team Dave)
BASE is on a distinguished road
What do you guys think about a 6WD with 4 outside pneumatic wheels and 2 8" omni wheels in the centre? Is it cause it'll negate the whole point of dropping the centre wheels? This ideas really been floating around with me because I don't want our team to have to rely on the bridges, that could cause for some hectic traffic. You think that'll help the whole turning issue with just pneumatic wheels?
This is actually my first post, so if it's a stupid question I understand
Unread 09-01-2012, 04:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Can you please explain how these wheels would achieve more speed out of any particular motor?
In addition, the pneumatic wheels supposed improvement in traction is merely a result of increased contact with the floor. Because traction treads do not act ideally (they intermesh with the carpet), there is more to the story than simple normal force.
You can achieve the same amount of traction by using wider wheels to match the pneumatic's contact area.
469 did not use a swerve drive last year or the year before, and they were fairly successful at turning.
