Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
  #31   Spotlight this post!
Unread 07-01-2012, 21:43
Mongai's Avatar
Mongai Mongai is offline
Indian Guy
AKA: Alec
FRC #0935 (RaileRobotics)
Mongai is just really niceMongai is just really niceMongai is just really niceMongai is just really niceMongai is just really nice
Re: Let's Talk About The Bridge:
Originally Posted by davidthefat View Post
My guess is, like most years, the majority of the robots will be around 120 lb and it would be relatively easy to balance one or two on the bridge.
Ah, but remember that robot weight isn't evenly distributed.
  #32   Spotlight this post!
Unread 07-01-2012, 21:46
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
What about this scenario:
Eliminations, you have two robots on your alliance bridge and one robot on the coopertition bridge (and thus prevent your opponent from scoring on the coopertition birdge):
You get 20 points for the 2 robots on the alliance bridge and 10 points for the robot on the coopertition bridge, meanwhile preventing your opponent from scoring 10 points because you prevent them from using the coopertition bridge.
Unless your opponent could get 3 robots on their bridge, this scenario would come out the same as if you got 3 robots on a bridge and they got one robot on the coopertition bridge in terms of point differential.
I think the bridge will prove to be pivotal because not only do I think the points are weighted more balanced than in past years (...minibots), but also because FIRST reserves the right to change the point values come Championships.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
  #33   Spotlight this post!
Unread 07-01-2012, 21:49
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
The Coopertition bridge scores no match points.
G40:
When the final score is assessed per [G37], a Balanced Alliance Bridge, per Section 2.2.5, earn points
(note that the coopertition bridge is excluded from this rule)
And G41:
If a Robot from each Alliance is balanced on the Coopertition Bridge when the final score for a Qualification Match is assessed per Rule [G37], each Alliance earns 2 Coopertition Points.
(note that the coopertition bridge scores only coopertition points in this rule)
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #34   Spotlight this post!
Unread 07-01-2012, 21:59
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So in other words, go big or go home.
  #35   Spotlight this post!
Unread 07-01-2012, 23:21
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
If you made a wide base robot you could have a larger intake and more easily fit 3 bots on a ramp.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
  #36   Spotlight this post!
Unread 07-01-2012, 23:27
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I think getting 3 bots on will work well if the last bot to get on has a bridge lowering device.
461 Westside Boiler Invasion
45 Technokats
  #37   Spotlight this post!
Unread 07-01-2012, 23:46
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
How much force is required to bring the ramp down?
It's ~10 lbs at an end of the bridge. (estimation)
Originally Posted by KrazyCarl92 View Post
What about placing an accelerometer on the robot that allows it to autonomously balance on the bridge? You could have it detect when you are unbalanced on the bridge then press a button that activates the auto-balance and drives to correct the imbalance. Just tell whomever you are balancing with that you have this auto-balancing feature and you have yourself 20 points or 10 points and a 2 point CP bonus as the case may be!
That's actually ridiculously easy; I coded that from scratch on the 1hr drive back from the kickoff.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
  #38   Spotlight this post!
Unread 07-01-2012, 23:58
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
just put your battery on a linear slider and rack and pinion...
  #39   Spotlight this post!
Unread 08-01-2012, 08:56
jreuter jreuter is offline
FRC #1073 (Force Team)
jreuter has a spectacular aura aboutjreuter has a spectacular aura about
[G37] Final scores will be assessed 5 seconds after the Arena timer hits zero.
So, whatever you do to balance, make sure it stays in position after you lose power.
  #40   Spotlight this post!
Unread 08-01-2012, 09:58
pfreivald's Avatar
AKA: Patrick Freivald
An omnidrive robot can more easily fit, too.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #41   Spotlight this post!
Unread 08-01-2012, 10:21
Djur's Avatar
WPILib
AKA: Sam Carlberg
Omniwheels wouldn't be too useful because they can slide very easily and don't have good traction; Mecanums are a bit more helpful because they don't slide as easily and have better traction; holonomic drive would be best because it doesn't sacrifice traction for mobility, but it's difficult to create. Just my 2 cents.
  #42   Spotlight this post!
Unread 08-01-2012, 10:26
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I guess this thread would be good to talk about how teams plan on moving the bridge from the static position down to court level so the robot can get on the bridge.
Are you going to stick a wedge on top of your robot to push it down on the other side for an alliance member? Are you going to build something that knocks it down on your side? Are you going to put legs on the robot so it can jump, or something else?
  #43   Spotlight this post!
pfreivald's Avatar
I meant omni-directional, not necessarily "omni wheels" -- so this would include mecanum, swerve, etc, etc.
Some kind of deployable traction device would be desirable if these are used, of course.
Team 1551
I write books, too!
  #44   Spotlight this post!
Unread 08-01-2012, 12:32
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
The tipping point seems to be ~54 lbft of torque, as per the 5th Field Tour video.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
  #45   Spotlight this post!
Unread 08-01-2012, 12:35
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
So at 1.5 feet out from the center, around 36 lb is required to tip it. How much does a battery weigh?
