Go to Post Look guys, I am telling you for the fourth time - you are NEVER going to earn your official "Geek" certificates if you keep spelling "pwned" with an "O" in it! - dlavery [more]
Unread 08-01-2012, 08:00
AKA: Brad
#0190 ( Gompei and the Herd)
New version of the Windriver update posted
There was an error in the installer that was posted for the C++ WPILib update to Workbench. It was missing the WPILib.a library. A new version has now been posted and is available on FIRSTForge.
http://firstforge.wpi.edu/sf/frs/do/...2_update_for_c
Sorry about the mistake.
Brad
Brad Miller
Robotics Resource Center
Unread 08-01-2012, 08:38
kccowan kccowan is offline
AKA: Ken Cowan
FRC #1073
kccowan is an unknown quantity at this point
Re: New version of the Windriver update posted
Brad,
I don't see any files when I follow that link.
KC
Unread 08-01-2012, 08:45
AKA: Brad
It's back now. There was an error when I gave it a test. I got nervous and temporarily removed it. It turned out to be an older image on my cRIO, and I replaced the update. Let us know if you have any issues.
Brad
Brad Miller
Unread 08-01-2012, 12:58
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Thanks Brad!
-Collin, 1138
Unread 08-01-2012, 16:29
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
So I've got the two new .zip files from NI, but they are password protected. What is the decrypt password?
Thanks,
bob
Unread 08-01-2012, 16:43
Da' Mentor Man
FRC #1967
Ok - the password is the one from kickoff: !HotShots!KnowBalance!
Now...next problem -- I got the program to run and find my cRIO no problem, but I can't find the FRC_2012_*.zip file. Where is it?
Thanks,
bob
Unread 08-01-2012, 17:35
Da' Mentor Man
FRC #1967
Aha!
So, for C++, Brian mentioned the NI updates in links here....
but there is also a link at the bottom of that page which is the actual C++ workbench update that contains the cRIO image in it at:
http://firstforge.wpi.edu/sf/frs/do/...h_update_v2993
Unread 12-01-2012, 21:12
scree0114 scree0114 is offline
FRC #3642 (Huskies)
scree0114 is an unknown quantity at this point
How do u decrypt the d link from last years competition?
Unread 12-01-2012, 21:23
AKA: Brad
Plug a laptop via Ethernet into the switch on the Dlink. Then using a web browser connect to it, should be 10.x.y.1. The from the web setup pages turn off WPA encryption.
Brad
Brad Miller
