Go to Post Engineers crave and demand facts, and won't reach a conclusion without them. - Richard Wallace [more]
Unread 07-01-2012, 23:39
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
<G33>
[G33]
During Teleop, Players must be within their Alliance Station. Inbounders who were in the Kinect Station during Hybrid must return safely and expediently to their Alliance Station at the start of Teleop. Inbounders must remain behind the Starting Line during the Match. Exceptions will be allowed in cases involving Player safety.
Violation: Foul
Emphasis mine. Does this mean that you have to throw/toss the balls onto the ramp at the Inbounder Station? Or are you able to lean towards it. In better words, is this rule stating that the Inbounder's feet can't cross the Starting Line, or that you can't break the vertical plane of the Starting Line AT ALL?
Unread 07-01-2012, 23:47
dudeman2009 dudeman2009 is offline
Electrical/pneumatics
AKA: Jon
FRC #1504 (The Desperate Penguins)
Team Role: Electrical
dudeman2009 is an unknown quantity at this point
Re: <G33>
My interpretation of the rule is that the vertical plane must remain unbroken.
“Inbounders must remain behind the Starting Line during the Match.”
I am going to plan on the entire inbounder including any and all appendages and clothing must remain behind the line.
Give me your MntDew... Now.
Unread 08-01-2012, 00:50
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: <G33>
Look at section 2.2.6/2.2.7 - the inbound station has a funnel on it. I think you're supposed to simply place the balls in the funnel, and have them roll out to the field. Also, note that the corral is inside the starting line - in order to pick up balls, the inbounder will have to reach across that line.
Unread 08-01-2012, 13:10
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
Re: <G33>
This video should clarify it:
http://youtu.be/IaFiCbZLPRY?t=34s
Unread 08-01-2012, 17:23
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: <G33>
It looks like the Starting Line does not continue across the front of the Corral, so there should be no problem with the rules here. It does go across the slot, though, so robots will basically have to pick balls up off the ground...
Does anyone else remember when TBA signatures actually worked?
Unread 08-01-2012, 18:02
AKA: Scooby
Re: <G33>
Not necessarily. If you have a hopper or some sort of opening in your robot that can place itself in front of the majority of the slot at the Inbound Station, you should be fine.
Unread 10-01-2012, 20:09
nssheepster's Avatar
nssheepster nssheepster is offline
Da' Rule Man
AKA: Nik Shepherd
FRC #0174 (Arctic Warriors)
nssheepster is an unknown quantity at this point
Re: <G33>
I think something that big will be covered long before competition. My guess is that they don't want Inbounders swapping out with or aiding the Drivers. So, you can't, say, grab a joystick and get going after you direct the robot via Kinect.
In theory, this should work.
In practice, not so much.
F.I.R.S.T. = For Inspiration and Recognition of Science and Technology
So really, it's F.I.A.R.O.S.A.T.?
Nah, that doesn't sound as good.
Unread 13-01-2012, 01:17
rich2202 rich2202 is online now
FRC #2202 (BEAST Robotics)
Re: <G33>
2.2.6 "The Starting Line is marked on the floor 4 ft back from the Alliance Wall, and extends across the width of the Alliance Station"
Seems like it does include the Corral and the Inbound Station. There should be an exception for those two areas.
Unread 14-01-2012, 14:09
Da' Rule Man
AKA: Nik Shepherd
Re: <G33>
Uh, one of our mentors aspires to GDC. He thinks we'll just have to throw it into the funnel over the slot. And the corral is on the line. He's usually right, so we're planning on it.
Unread 14-01-2012, 19:50
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Re: <G33>
I'm not sure what your mentor wanting to be on the GDC has to do with the rules. What do you mean by 'throw it into the funnel over the slot'? You can only throw balls over the wall in the last 30 seconds.
Unread 14-01-2012, 20:54
DonRotolo's Avatar
Back to humble
FRC #0832
Re: <G33>
I think you have missed the issue.
Inbounders must stand behind the starting line, about 4 feet from the hole/slot for putting balls back onto the field. The issue is, can they reach over the "starting line" or not.
The rules are very clear for your issue:
[G36] During a Match, the operator console shall be operated solely by the Drivers of that team. Violation: Technical-Foul
Drivers are identified by Driver Badges.
Unread 14-01-2012, 21:34
musicgurl1329's Avatar
musicgurl1329 musicgurl1329 is offline
steampunk emcee
AKA: Nikki Panda
FRC #0148 (Robowranglers)
musicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud ofmusicgurl1329 has much to be proud of
Re: <G33>
Technically, wouldn't this person be the 3rd human player? Or is there a rule I missed saying there can only be 2 human players?
Panda
Emcee
Midatlantic District Outreach Co-Chair
Team 148 Mentor
2016-????
Team 2495 Mentor
2015-2016
Team 1089 Mentor
2012-2016
Unread 15-01-2012, 03:26
Re: <G33>
Rule G04 "Each FRC team provides up to four Players (a Coach, two Drivers and an Inbounder)."
Unread 17-01-2012, 07:33
Da' Rule Man
AKA: Nik Shepherd
Re: <G33>
He's old enough to help, and usually runs the floor crew at Finger Lakes Regional. That's why. Throwing it into the funnel is not over the wall. And the top of the funnel is below the wall but past the starting line.
Unread 17-01-2012, 09:01
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: <G33>
For what it's worth, this question is posed on the Q&A. Now we can all stop name-dropping, ego-pumping, and wishfully conjecturing that the rule is one way or the other.
Originally Posted by Team 4334
Game - The Game » Human Actions » G33
Q. Does this rule mean that inbounders cannot step over the Starting line. Or that no part of their body may pass the vertical projection of the line?
https://frc-qa.usfirst.org/Questions.php
GitHub
