Go to Post Do not under estimate the wood bots and brave little toasters! - hipsterjr [more]
Unread 01-08-2012, 01:43 PM
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
Re: 2012 Windriver Install problem
In the instructions it said to be sure not to run WindRiver 3.0 after you install disk one. If you did, you would get an error when you tried to run 3.3. You have to kill the WindRiver Registry in your taskbar. Also look for the WindRiver Registry in Task Manager and kill it. Then run 3.3. That should work.
Also, make sure you install all of the National Instruments Software or you will not see the FRC Examples.
If you need any more help, just ask me. I had the same issues and fixed it this morning.
-Eagle Engineering 1138
