Go to Post Now please, go have some meaningful discussions that will inspire us all. - Ken Leung [more]
Unread 07-01-2012, 20:19
NagyH NagyH is offline
NagyH has a spectacular aura aboutNagyH has a spectacular aura about
2012 Throttle Control Motor Information
Hello all,
I'm trying to find some information regarding the Throttle Control Motor (PN: AE235100-0160). Does anyone have any motor curves or technical specs?
Thanks.
Unread 07-01-2012, 20:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 2012 Throttle Control Motor Information
Info's on the FIRST Choice page for the motor:
http://www.andymark.com/Throttle-mot...-p/fc12-20.htm
5300 free RPM, 18.4 oz-in @ 7A stall
Unread 07-01-2012, 22:11
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Since the power leads are strangely on the same side as the output gear (not even an inch away from it, really), does know if there are good COTS solutions to hooking this thing up to a typical actuated situation?
Attending: MN Duluth Regional
Unread 08-01-2012, 15:10
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
http://www.usfirst.org/sites/default...r%20Info_0.pdf
^not exactly a COTS solution, but this document provides info about the output gear so one can find another gear that will mate with it (20 PA, .75 module). Basically, you would face mount it to a plate and either mesh it with another ear that turns a shaft that acts as the input for a cots gearbox, or you build a custom gearbox. That being said, besides the vex motors, it is the least powerful motor in the kit, and since the vex motors have gearboxes attached and easy to find interface options (from VEX), the throttle control motor might just be the worst motor in the kit.
Edit: I'm not saying it isn't useful, I'm just saying it has fewer practical uses than most motors and it is harder to use as well, unless a cots gearbox is found.
