Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 08-01-2012, 15:38
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: 4wd wide base: Looking for videos, experience, comments and thoughts
Our team on kick off day built the 4 wheel wide version of the kit frame.
Photo/Video here: http://www.youtube.com/watch?v=AnIGj...ature=youtu.be
In a short test of driving it around, it seemed pretty nimble and quick.
Might gear it lower however.
We did have it go over a 2x4 seemed to be okay.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-01-2012, 11:15
viperred396's Avatar
viperred396 viperred396 is offline
people have lives during January?!?
AKA: Bryan
FRC #2240 (Brute Force)
viperred396 has a spectacular aura aboutviperred396 has a spectacular aura aboutviperred396 has a spectacular aura about
Vid?
2010 CO Regional: Finalist
2007 CO Regional: Semi-Finalist
Unread 10-01-2012, 14:08
Rabajaka Rabajaka is offline
FRC #2034
Rabajaka is an unknown quantity at this point
Another advantage to going with 4 wide is that the 6 wdr with the middle wheel being lower then the other ones making the bot rocking back and forth when the bot is shooting
Unread 10-01-2012, 14:16
Nick LaPosta Nick LaPosta is offline
FRC #2495 (Hornets)
Nick LaPosta is an unknown quantity at this point
Send a message via AIM to Nick LaPosta
That would depend on where your weight is centered at. The ball isnt going to create much rock if any if your weight is centered low and to the front.
Also on the four wheel drive, my team had a four wheel drive in 2010 and we had trouble steering. You want to try to keep your wheels as close together as possible while still being stable. Otherwise you end up dragging the wheels across the floor making it difficult to turn. That was with the standard rubber 6 in" wheels.
TEAM 1647 - Mentor
TEAM 2495 - Mentor
Unread 10-01-2012, 14:45
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
But the barrier is 4x6... do you guys plan on using bridges exclusively? We're looking to do a similar setup but with the 8'' wheels.
Unread 10-01-2012, 17:38
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Our 2010 robot used a 4 wheel swerve drive with 2 modes. One mode is strictly translating in a crab drive mode, but the other is with the wheels straight operating as a wide base 4WD. It uses 6" FIRST wheels. Here's a video of it playing breakaway:
http://www.youtube.com/watch?v=LvHBv...yer_embedded#!
When the robot is moving sideways that won't give you a good idea about the maneuverability of what you are thinking of. But when the robot is moving strictly forward/backward and turning, that is exactly the type of maneuverability you are interested in seeing! It may be tough looking at the video for the first time to differentiate between when its in swerve vs. tank mode, but it's there!
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
